954 front wheel - Honda Motorcycles - FireBlades.org
post #1 of 10 Old 06-02-2009, 10:40 PM Thread Starter
954 front wheel
i just swaped the rear wheel with a rc51 sp-2 5 spoke wheel but does anyone know if the front is a direct swap or which 5 or 6 spoke wheel is a direct swap to a 03 954
ridenonfire is offline
post #2 of 10 Old 06-02-2009, 11:02 PM
MACI4LIFE is offline
post #3 of 10 Old 06-03-2009, 1:55 AM
Re: 954 front wheel
You'd have to replace the bearings, seals and spacer to fit the 25mm axle.
Discs are the same pattern.
post #4 of 10 Old 06-03-2009, 5:23 PM Thread Starter
Re: 954 front wheel
ok this is for the rc wheel your talking about and the parts are they the ones i currently have in the 954 wheel
post #5 of 10 Old 06-03-2009, 9:25 PM
Re: 954 front wheel
Yes, the RC wheel is what you asked about.
The bearings would probably fit but I'd recommend new bearings - they're not expensive.
The bearing spacer I would expect to fit but measure it to be sure. If it's too short the bearings will bind and if it's too long the bearings won't fit fully into each side of the wheel. You could make some shims to go into the wheel under the bearings if the spacer is longer than you need but I probably wouldn't shim the spacer if it's too short.
If you can get somebody to measure the width of the bearings in each of the wheels that'll tell you the spacer length without having to disassemble them. You could alternatively make the RC axle fit the 954 forks but I'd have to look at what that would involve.
With all modfications I always recommend taking your own measurements before spending your money regardless of what anybody (including me) tells you will work. It's your money and only you know how much fabrication you're comfortable with.
post #6 of 10 Old 06-03-2009, 9:36 PM Thread Starter
Re: 954 front wheel
good info i will look in to it and post a reply with what i ended up with
post #7 of 10 Old 06-04-2009, 3:33 PM
Re: 954 front wheel
is there any performance benefit to this swap or is this just cosmetic or replacement necessity? i wouldve thought the 954 wheels are lighter?
03' Blk/Tit CBR 954rr, Erion full system, PCIIIr, Scott's Damper, Vortex Frame Sliders, Galfer SS Lines, Rear Seat Cowl, flapper pinned.
vertical954rr is offline
post #8 of 10 Old 06-04-2009, 8:25 PM Thread Starter
Re: 954 front wheel
replacing b/c i allready got a rc51 on rear due to a necessity now wanting to match the front to rear also i like the 5 spoke better than trispoke
post #9 of 10 Old 06-04-2009, 10:05 PM
Re: 954 front wheel
From another thread the 954 front wheel is around 200gms lighter than the RC51 wheel.
post #10 of 10 Old 06-06-2009, 6:22 PM
Re: 954 front wheel
you wouldnt want to sell that front stock rim on the 954 I need a front
Cbr954Victoria is offline
F3 17in. FRONT WHEEL & WIDEN REAR WHEEL BY KOSMAN FOR CBR 900RR! ajdapilot For Sale 2 06-14-2008 6:46 PM
WTB: SP2 FRONT WHEEL hybrid For Sale 0 05-13-2008 9:24 AM
CB 599 front wheel HONDA PIMP Wanted 0 04-14-2007 11:12 AM
Need a 929 front wheel..... DRAGRACR For Sale 0 03-02-2007 12:38 PM
FS: 00 F4 Front Wheel / 04 599 front and rear wheel dragn_cbrf4i For Sale 0 01-30-2006 5:27 PM
