954 indicator relay - instrument cluster?? - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 06-30-2009, 9:53 AM Thread Starter
My turn signals stopped working so I whipped out my workshop manual which said the relay is kept in the instrument cluster. I'm fairly sure it's failed, how the heck do you replace it? Isn't the cluster linked to the ECU so you can't just swap over a new one?
soupnazi is offline
post #2 of 6 Old 06-30-2009, 10:44 AM
Re: 954 indicator relay - instrument cluster??
I don't believe it's possible to replace the relay so please send Mr Honda $600 for a new instrument cluster ;-)
If you search there are several threads explaining how to circumvent the cluster and run a new relay in the circuit.
There's no problem with replacing the cluster. You don't need the cluster at all.
post #3 of 6 Old 06-30-2009, 12:00 PM
Reputation Power: 12
Here's the thread I used and a pic of the splice point I took during install......
https://www.fireblades.org/forums/hon...her-relay.html
100_1655.JPG‎
The only thing I trust on the road are the nine hundred and fifty four CC under me..........
flipsidenv is offline
post #4 of 6 Old 10-03-2010, 4:46 AM
Did you put this relay in a 94 cbr 900? My turn signals went out also and I cant find were the original relay is, did you keep the stock relay in the system?
BlacLightingCBR is offline
post #5 of 6 Old 06-10-2011, 9:05 AM
1993 cbr 1000 , is it built in cluster too built in cluster
willys1950 is offline
post #6 of 6 Old 06-10-2011, 9:33 AM
No, the CBR1000F relay is in the tail.
WTB 929 Instrument Cluster Zach929rr Wanted 1 05-15-2009 1:13 AM
Instrument Cluster on 954 bigM954 Honda FireBlade 2 04-24-2009 8:39 AM
Looking for '01 929 Instrument Cluster brosio Wanted 6 06-06-2008 7:27 AM
Instrument Cluster - 93 900RR jsidhu Honda FireBlade 21 07-04-2007 3:21 AM
Instrument cluster went out HELP PLEEZ FullForce General Discussion 7 06-27-2004 9:57 PM
