929 engine problem - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 07-04-2009, 12:46 PM Thread Starter
929 engine problem
Whats up guys I have a 01 929 with a 954 engine. I got it off a guy local as a bike in a box guess he didnt want to finish it. Anyways I had a friend put the engine back together and all. Got it running today. Runs good shifting is a little harsh but the problem is when i lean the bike to the right side(only the right) it starts making a clacking noise and when i lean it over a little more it jumped into gear. Now keep in mind the motor is running perfect so maybe this is gotta be in the trans??? Help please....
929ryder is offline
post #2 of 6 Old 07-04-2009, 1:00 PM Thread Starter
Re: 929 engine problem
ok guys just tried leaning it to the right when started and in gear with the clutch pulled in. there is no niose then. dunno if this helps. also before we put it all back together we checked to see if any dogs were worn they looked good and the shift forks looked fine. Since it only does it in neutral would it be ok to ride it???
929ryder is offline
post #3 of 6 Old 07-04-2009, 8:41 PM Thread Starter
someone told me it could be that the **** detent is not properly aligned, does this sound right?
929ryder is offline
post #4 of 6 Old 07-05-2009, 12:17 AM
D.S
Sounds like you'll have to get behind the clutch and check the operation of the gearshift.. I'm guessing that while in neutral the gearshift drum could be forced to turn into gear by the weight of the gears/shiftforks and vibrations when you lean the bike, IF the stopper mechanism isn't keeping the drum from rotating. So I'd look there first.. is the stopper fully and firmly engaging the neutral "groove" on the drum? Just guessing, I'm sure someone else here could make a more informed guess..
D.S is offline
post #5 of 6 Old 07-05-2009, 10:55 AM Thread Starter
dang sounds like i may have to pull the motor and split the cases again.
929ryder is offline
post #6 of 6 Old 07-05-2009, 12:31 PM
D.S
Check the gearshift behind the clutch before, no need to pull the motor or split the case for that.
D.S is offline
Engine Problem and Question Bmeath Honda RC51 8 08-25-2009 7:26 AM
929 engine problem kenobi408 General Discussion 3 01-16-2009 3:03 PM
Engine problem on my 2001 F4i unreal_civic Honda CBR 600 6 06-23-2008 2:13 PM
engine serious problem breimers Honda RC51 3 06-11-2008 10:54 PM
engine problem? xr312 Honda FireBlade 5 06-21-2006 11:00 PM
