99 900RR Fuel Problem....................???? - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 07-05-2009, 2:50 PM Thread Starter
Hello All,
I have a pretty serious issue with my bike. When I fill the tank (usually 92oct.), I am not getting noe where near the milages that I| used to get, and to top it all off the reserve tank is being used in the on fuel position, so when I run out of gas I am screwed. I am also getting this weird "bogging" sound when I ride like the bike is under water. I just asummed that this is all because of a fuel issue. Thanks for the help !!!
BuzzDatAzz is offline
post #2 of 6 Old 07-05-2009, 4:07 PM
Quoted: 6 Post(s)
Reputation Power: 26
Re: 99 900RR Fuel Problem....................????
Clean the carbs and then read the plugs
ghbzorro is offline
post #3 of 6 Old 07-05-2009, 6:53 PM
Originally Posted by BuzzDatAzz View Post
Hello All,
Sounds to me like the diaphram is torn in the fuel tap.
Pull the vacuum line off and see if fuel comes out of it.
post #4 of 6 Old 07-07-2009, 6:22 PM Thread Starter
Thnx for the help guys!!! It appears the problem is gone, it was because of me switiching up fuel, I was using Wawa gas, then the other day I switched and used Getty, bug mistake, now that I have switched back it runs fine. I do have 24000+ miles so at this point the engine can be very tempermental about gas quality.
post #5 of 6 Old 07-07-2009, 7:13 PM
Reputation Power: 11
what is the difference in these fuels?
in the uk we have standard unleaded and super.
johnx144 is offline
post #6 of 6 Old 07-08-2009, 3:31 PM Thread Starter
Well, some gas stations have better or should I say cleaner fuel, the octane is the same,but some gas brands are just bad and Getty is one of the bad ones. Wawa has good gas like Exxon, Sunoco, etc. the bike runs like new again now that I have switched back to my regular brand.
Fuel injection problem that929 Honda FireBlade 42 09-30-2010 8:57 PM
fuel problem brett Introductions 3 11-30-2007 7:08 AM
HELP!!! Please 02 954 Fuel pump problem rogers954 Honda FireBlade 4 09-27-2007 12:52 AM
02' CBR600F4I - Fuel problem laurenvictoria7 Honda CBR 600 2 07-05-2007 10:09 AM
Fuel problem deez Honda RC51 22 05-27-2004 10:07 PM
