02 954; pouring fuel from exhaust..help! - Honda Motorcycles - FireBlades.org
post #1 of 9 Old 09-08-2009, 1:00 AM Thread Starter
I have an 02 954 with an issue that randomly just arose the other day. I was riding it, and it began losing power. When I jumped on the gas it fell on its face, and I turned around to notice some white smoke coming from the pipe. A few seconds after, I looked on the ground and it was POURING, and im not exaggerating; there had to be 1 qt's worth of fuel on the ground. When cranking after that, it just fills the cylinders with fuel and locks up. If the fuel pump is disconnected it will come to life and run normally for a few seconds, but as soon as I reconnect it; same problem occurs. Any ideas?
Mcskillet is offline
post #2 of 9 Old 09-08-2009, 1:14 AM
Reputation Power: 78
Re: 02 954; pouring fuel from exhaust..help!
Welcome to the forum first off!
Have you checked your fuel lines from the tank to the fuel rail?
Are you getting spark?
BurtonF166 is offline
post #3 of 9 Old 09-08-2009, 1:22 AM Thread Starter
Yea, fuel lines from the tank to the rail are clean and flowing well..also, plenty of spark...it will run maybe only about 3 seconds before the fuel is shooting out of the exhaust. And its firing on every cylinder. its totally weird...like the injectors are stuck wide open or something.
post #4 of 9 Old 09-08-2009, 1:31 AM
Interesting. Have you tried an ECU swap with another 929?
post #5 of 9 Old 09-08-2009, 2:43 AM
Reputation Power: 11
well it sounds to me like the spring in the injector might have collapsed and not allowing it to close. It might run fine for three seconds due to its a pressurized system and with no pressure it is just trickling through the orifices for the injectors. Maybe pull them and have them checked for flow and make sure they are still good. Just my thought.
Iceman396 is offline
post #6 of 9 Old 09-08-2009, 6:11 AM
Fuel pressure regulator.
Pull the vacuum hose off and it's probably wet with fuel.
post #7 of 9 Old 09-08-2009, 6:21 AM
sscottab's Avatar
Reputation Power: 17
a couple things to look at, the fuel pressure regulator, the ecu or the injectors sticking.If they are all flooding i would rule out the injectors themself unless something else has damaged them all. if the pressure regulator has stuck and increased the fuel pressure to the point to damage the injectors or push fuel past when close would flood out. If you have access to another ecu i would recommend swapping it out and checking because the ecu controls the injector opening and closing also known as injector pulse. is there any codes stored because there should be a cam or crank sensor that will tell the ecu when to open and close the injectors.
2002 CBR954RR
scott
www.itriderz.com
sscottab is offline
post #8 of 9 Old 09-08-2009, 6:27 AM
The fuel pressure regulator doesn't get stuck.
The diaphram tears allowing fuel to bypass the injectors entirely.
post #9 of 9 Old 09-09-2009, 3:04 AM Thread Starter
Spot on with the fuel pressure regulator...I pulled the vacuum hose off of the fpr just after a start attempt and it was def. wet with fuel. I ordered a new fpr today ($90 Bucks! whoa) and hopefully this solves the problem. Ill let you guys know...thanks for all the help, this forum really is great and one of the best motorcycle forums on the net. thanks again!
Fuel Tank / Fuel pump seal ugt33 Honda RC51 0 10-24-2008 2:13 AM
Help! Fuel Dripping From Exhaust. styxer Honda FireBlade 6 11-21-2007 7:30 AM
00 929 exhaust servo or fuel problem need help danw82 Honda FireBlade 6 10-18-2007 2:26 PM
FS/FT: Exhaust, Headers, Fuel Pump and Tank kaneda_77 For Sale 5 01-25-2007 1:16 PM
Fuel / Exhaust valve & Cat. convertor wynand General Discussion 0 06-29-2004 10:38 AM
