929/954 front Brake calipers - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 09-09-2009, 2:01 PM Thread Starter
Are they the same and interchangable? how can I get a sticky caliper piston to move freely?? Anyone have info on these questions. Thanks
[email protected]
dave6688 is offline
post #2 of 4 Old 09-09-2009, 2:34 PM
Reputation Power: 12
Re: 929/954 front Brake calipers
They are interchangeable. However, I thought I read somewhere in the "what's new for 2003" articles that Honda changed the diameters of the pistons for better braking feel. If you are going to change one, change both of them to keep a matched set.
Donnyballgame
Work Hard, Play Hard.
Donnyballgame is offline
post #3 of 4 Old 09-09-2009, 3:34 PM Thread Starter
thanks so much. the 954 calipers are $100 usd cheaper than the 929 for a set and someplaces for one.
dave6688 is offline
post #4 of 4 Old 09-09-2009, 11:47 PM
[email protected]
They are interchangeable (along with some others including the F4i I think) but they aren't identical as already stated.
It would depend on why the piston is stuck, but if it's not actually damaged it should be repairable. You'd need to disassemble the caliper and blow the pistons out with air if you can't just push them out with hydraulic pressure.
Replace the seals and polish the pistons and lube everything with brake fluid during reassembly.
Different Brake Calipers D03Cobra Honda FireBlade 14 12-01-2008 1:35 PM
WTB: Nissin front brake calipers from RC51 SP1 GlennCauley Wanted 1 11-25-2008 12:52 PM
Need new brake calipers kirkos86 Wanted 6 11-18-2008 12:39 AM
FS: front brake calipers off a 94 CBR 900RR dmack For Sale 1 10-25-2007 12:53 AM
929RR Front Brake Calipers Fastrr Honda FireBlade 0 03-26-2007 9:14 PM
