honda 929 dropped on side.Now wont start ? - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 09-12-2009, 6:25 PM Thread Starter
Please can anyone help?
I have a 2000 929 blade with less than 4000 miles on the clock.
Some nice chaps decide to try and nick it from my garage. They got disturbed and dropped it on its side.
The bike work perfect before this all happened and was running fine.
The fuel pump does not seem to prime on the turn of the key. The engine does turn over but wont start. I powered up the fuel pump with a separate feed. Pump fired up fine but bike still will not start. The LED by the side of the key picture on the dash stays on. Can’t remember if this should go out when you turn the ignition on? I have check the cut out switch by the rear tank mount. I was told to give it a tap but still no joy. Can this be tested ?
How do I get the bike into diagnostics?
Please please help ! I want to get out for a ride.
Cheers for now.
guffblade is offline
post #2 of 8 Old 09-12-2009, 6:42 PM
Reputation Power: 59
Re: honda 929 dropped on side.Now wont start ?
I take it you have Hiss on your bike? Does the Hiss light remain illuminated?
Was thinking of the tip over sensor before hand... and maybe the switch gear? (i.e. the red cut off switch) - was anything damaged?
Twincam is offline
post #3 of 8 Old 09-12-2009, 6:59 PM
The fuel pump does not seem to prime on the turn of the key. The engine does turn over but wont start. I powered up the fuel pump with a separate feed. Pump fired up fine but bike still will not start. The LED by the side of the key picture on the dash stays on. Canít remember if this should go out when you turn the ignition on? I have check the cut out switch by the rear tank mount. I was told to give it a tap but still no joy. Can this be tested ?
Cheers for now.
If they tried to start it or break the steering lock, they may have damaged the HISS sensor or its wiring.
post #4 of 8 Old 09-12-2009, 8:10 PM
Good thinking Batman!
Check the wiring!
Twincam is offline
post #5 of 8 Old 09-13-2009, 2:53 AM Thread Starter
Hi, thanks for the reply.
Yes it has HISS fitted. I assume the picture of the key on the dash with the LED next to it is the HISS light. When you turn on the ignition the light remains on ? not sure if that is correct ? It does ficker when I pust the start button.
The switch gear is intact with no damage. A few scratches on the side panels and that was it.
Could the tip over sensor be faulty ?
Cheers for now.
Gary
post #6 of 8 Old 09-13-2009, 2:56 AM Thread Starter
Ignition and steering lock is fine with no damage.
How do I get the bike into diagnostics ?
Cheers for now.
Gary
post #7 of 8 Old 09-13-2009, 2:58 AM
Cheers for now.
Gary
Diagnostics mode only diagnoses Fuel Injection related problems. If it has an error it will flash a code on the dash.
post #8 of 8 Old 09-23-2009, 6:06 AM
hey guff simple fix try flicking kill switch on then off again these bikes are designed to kill the electrics when dropped
snag is offline
Honda cbr f3 Wont start HELP!!! please fflstrauss General Discussion 8 05-26-2009 10:59 PM
honda VF 750 1983 wont start leetrials Honda Interceptor / VFR 0 10-23-2007 8:46 AM
honda 954 wont start? camo954 Honda FireBlade 9 06-18-2007 1:25 AM
My 96 Honda F3 wont start! Help! chevyoffroad Introductions 1 02-28-2007 8:37 AM
2002 Honda 954 wont start sideshow General Discussion 8 11-18-2004 1:41 PM
