929 blade HISS light staying on ? - Honda Motorcycles - FireBlades.org
post #1 of 12 Old 09-14-2009, 4:27 AM Thread Starter
I have a 2000 929 blade.
The HISS light is staying on when the ignition is turned on and the bike wont start ?
I cant remember if the light should go out before the bike will start ?
Can anyone help.
Also fuel pump does not prime ?
Cheers
guffblade is offline
post #2 of 12 Old 09-14-2009, 6:10 AM
Re: 929 blade HISS light staying on ?
Check the HISS sensor circuit is intact.
post #3 of 12 Old 09-14-2009, 9:04 AM
Reputation Power: 59
Can anyone help.
Cheers
When I turn my key, the chip inside the key "connects" to the sensor (the surround around your ignition barrel which has HISS written on it). This is what starts the sequence off.
As Blade said, check the wiring as if the connection is not being made, it will not allow for the fuel pump to prime.
Twincam is offline
post #4 of 12 Old 09-14-2009, 9:12 AM
Actually, you don't even need to put the key in the ignition to trigger the HISS sensor.
I have my coded key cable-tied to the sensor which is mounted under the tank to keep it safe. I use a standard key copy to operate the ignition.
post #5 of 12 Old 09-14-2009, 9:19 AM
Ok ok my mistake. All you need is the chip to be near the sensor for it to pick it up.
Twincam is offline
post #6 of 12 Old 09-14-2009, 9:38 AM Thread Starter
I assume then that the HISS light should go out before the pump will kick in ?
post #7 of 12 Old 09-14-2009, 9:42 AM
Just went and tried it. The Hiss light stays on whilst the fuel pump primes. As soon as its pressurised the rail the pump stops and the light goes out.
Twincam is offline
post #8 of 12 Old 09-14-2009, 9:43 AM Thread Starter
So the light should go ouy then before the pump starts to kick in ?
post #9 of 12 Old 09-14-2009, 9:49 AM
Reputation Power: 78
Right
BurtonF166 is offline
post #10 of 12 Old 09-14-2009, 9:51 AM Thread Starter
Originally Posted by BurtonF166 View Post
Right
Cheers
post #11 of 12 Old 09-14-2009, 5:09 PM
Cheers
No worries. Whats the update?
Twincam is offline
post #12 of 12 Old 09-15-2009, 3:40 AM Thread Starter
Having a look at the bike tonight 15/09. I'm away working.
I will update you when I have had a play.
Thanks
I searched a lil found nothing. Fuel injection light coming on and staying on. beerock Honda RC51 6 09-08-2009 1:11 AM
fI and red light..954 blade.. iceman954 Introductions 3 03-21-2009 6:29 AM
HISS light doesn't work JakeT Honda FireBlade 7 09-17-2005 2:32 AM
Choke not staying put ibAdam Honda FireBlade 3 08-15-2005 8:13 PM
Hayden staying with Repsol for 2005 nedro Road Racing: Professional 6 09-09-2004 3:12 AM
