Tach stuck possible fix - Honda Motorcycles - FireBlades.org
post #1 of 11 Old 09-14-2009, 6:00 PM Thread Starter
Reputation Power: 12
My tach has been stuck on 4500 rpm ever since I changed out all of my led's. I took it all back apart and I found one little probe was broken off. The four probes are what powers and regulates voltage to the tach. Here are the pics.
The post are like this
TS+ TC-
TC+ TS- On mine the top TC- is broken
http://i33.photobucket.com/albums/d6...3/103_3831.jpg
http://i33.photobucket.com/albums/d6...3/103_3830.jpg
http://i33.photobucket.com/albums/d6...3/103_3833.jpg
DingDongGo is offline
post #2 of 11 Old 09-14-2009, 6:04 PM
Reputation Power: 59
Re: Tach stuck possible fix
Do you need to rebuild the needle at TC-? Could try using a paper clip but maybe a little too thick?
Twincam is offline
post #3 of 11 Old 09-14-2009, 6:15 PM Thread Starter
That is a really, really good idea. I can desolder the post and remove it then try a piece of paper clip. I will let you know how it works out
post #4 of 11 Old 09-14-2009, 6:55 PM
Make sure you can solder the paper clip first...? I.e. try it first as some materials don't like to "stick".
Twincam is offline
post #5 of 11 Old 09-14-2009, 7:13 PM Thread Starter
I will. I am gonna try a paper clip first and then I am gonna try a piece of copper wire from a tv cable, since it is about the same diameter and it is very stiff
post #6 of 11 Old 09-14-2009, 7:19 PM
Definatly worth a try.
Has it left a hole where you can put a part of the paperclip into?
Twincam is offline
post #7 of 11 Old 09-14-2009, 8:31 PM Thread Starter
Yes after I desoldered the probe it left a small hole. The paper clip was just right for the hole but was too big for the hole on the needle motor. It fixed the stuck needle and removed the red error light. Here are the photos it was a really easy fix.
TV cable I used the copper in the middle perfect size length can be trimed( I left it long just until I finished soldering) and was stiff enough not to bend easily.
http://i33.photobucket.com/albums/d6...3/103_3838.jpg
http://i33.photobucket.com/albums/d6...3/103_3834.jpg
http://i33.photobucket.com/albums/d6...3/103_3835.jpg
http://i33.photobucket.com/albums/d6...3/103_3836.jpg
http://i33.photobucket.com/albums/d6...3/103_3837.jpg
post #8 of 11 Old 09-14-2009, 8:36 PM
Good fix! Glad its all working!
Twincam is offline
post #9 of 11 Old 09-14-2009, 8:41 PM Thread Starter
Thanks Twincam
post #10 of 11 Old 09-14-2009, 8:47 PM
No worries, Glad you weren't scared to try something different.
Think you deserve rep
Twincam is offline
post #11 of 11 Old 09-14-2009, 9:05 PM Thread Starter
SCARED, I just don't know any better.
Tach Signal southpark460 Honda RC51 7 02-11-2012 10:32 AM
929 tach quit? eye toke Honda FireBlade 5 12-24-2007 8:20 PM
No power to tach? icon954 Honda FireBlade 4 05-10-2007 5:38 PM
Bouncing tach? Island Moose Honda FireBlade 8 08-02-2006 2:29 AM
Tach stuck at zero?!? SJ96F3 General Discussion 11 04-26-2006 11:20 AM
