'02 954 rr high engine rev when gas pulled .. - Honda Motorcycles - FireBlades.org
post #1 of 13 Old 10-10-2009, 2:34 AM Thread Starter
Aloha !
I have a '02 954 rr that i just got for free. The pre owner used the bike for drag racing on our track for a few times and installed a Powershifter. I fixed up the Bike so far so good and changed all gaskets etc. to avoid leaking and so far. Now that i removed the Powershifter i reconnected all wiring from the harness to the spark plugs to original. When i start driving and i pull the throttle to get forward my bike revs all the way up to 10 000 rpm stays there while i am slowly moving forward until i reach the speed the 10 000 rpm would be reasonable ... where do i adjust the idle when i pull throttle ? what did i miss ? Or is the Bike broken for good ?
808state is offline
post #2 of 13 Old 10-10-2009, 3:17 AM
Re: '02 954 rr high engine rev when gas pulled ..
Originally Posted by 808state View Post
Aloha !
Sounds like the clutch is toast.
Is the twist grip still functioning or is it jammed open?
The idle adjuster is mounted just in front of your left knee below the frame rail.
post #3 of 13 Old 10-10-2009, 3:35 AM Thread Starter
ok the clutch i believe .. i had to loosen the screw on the lever all the way out to tighten the cable that goes to the clutch . If the clutch is toast wouldn't my bike pull once i kick it into first gear ? dunno never changed a clutch yet.
the idle adjuster is only to adjust the idle while the bike is standing ? because that is just perfectly fine running by 0.9 - 1k
808state is offline
post #4 of 13 Old 10-10-2009, 3:41 AM
That would happen if your clutch mechanism wouldn't disengage.
Yours is slipping.
Perhaps it's got some kind of launch system that holds the revs steady?
post #5 of 13 Old 10-10-2009, 3:56 AM Thread Starter
Not that i've seen anything else than the Powershifter that i removed and the wiring is back to normal at the sparks. I couldn't see any changes when i took off the airfilter etc. everything seems to be normal. So you rekon to change the clutch ?
is it also normal for a toasted clutch that the engine revs high once you pull the throttle but no power at all or if .. than super slow ..
808state is offline
post #6 of 13 Old 10-10-2009, 3:58 AM
I don't know if you need to replace it but you definately need to investigate why it's not engaging. 10,000RPM makes it extremely likely that the plates are fried though.
post #7 of 13 Old 10-10-2009, 4:03 AM
When i start driving and i pull the throttle to get forward my bike revs all the way up to 10 000 rpm stays there while i am slowly moving forward until i reach the speed the 10 000 rpm would be reasonable.
The revs only stay up when the bike is in gear? Blipping the throttle in neutral is fine?
post #8 of 13 Old 10-10-2009, 6:16 AM
sscottab's Avatar
Reputation Power: 17
I agree with bladeracer sounds like the clutch.
have you road before or are you new to bikes.
2002 CBR954RR
scott
www.itriderz.com
sscottab is offline
post #9 of 13 Old 10-10-2009, 2:40 PM Thread Starter
Ok i just tried it this morning after i installed a new back tire. I started her up and drove down the road until 2k rpm everything seems fine but as soon as i pull the gas harder it goes up in rpm and not only to 10k it goes all the way and it takes forever before the bike is gaining speed. Yeah it is the clutch.
Yes i ride bike since 12 years , started with GSXR over R6 to cbr 600 now since 08 i have a 01 cbr 929 rr and just 2 weeks ago i scored this beautifull 954 . I am fixing her up because the pre owner was treating her like **** and he owed me a big favor so i called in the favor for the bike
I never had trouble with a clutch of any of my bikes because i either sold em or crashed em before any clutch problems could come up lol ...
I will replace the clutch as soon as possible . i just needed help with an idea after all i did already to the bike my brain was kind of stuck to think what could be next
Mahalo for your guys help i realy enjoy this forum
808state is offline
post #10 of 13 Old 10-10-2009, 7:17 PM
Does the twist grip still function or is it jammed open?
Does this only happen in gear or is it the same in neutral?
post #11 of 13 Old 10-14-2009, 12:57 AM Thread Starter
Today i opened my baby up and checked out the Clutch. Clutch still had meat and was clean and not realy burned but what i saw was actually that my cable was adjusted wrong. It was not totally releasing the clutch and thats why it made it slip. I put everything back together and adjusted the cable that i had about 1/4 inch play on the lever and when i held the clutch lever in first gear the bike doesn't jump forward. Now it works perfect i have my power back and took it right away for a spin and ran my baby on top of our Mauna Kea in 2600 feet elevation up to 174 mp/h
Thank you for your guys help and aloha ... cya in other posts
808state is offline
post #12 of 13 Old 10-14-2009, 3:03 AM
Reputation Power: 78
for easy fixes!
BurtonF166 is offline
post #13 of 13 Old 10-14-2009, 10:08 AM
Reputation Power: 12
I'm not sure if the 954 clutches are more resilient than others but My bike was originally a stunter before I got it. I figured the clutch would have been pretty eaten up but 4,000 miles after i got it its still smooth as butter and catches like a champ.
KSJNX is offline
cbr900 `95 issue ... at high rpm engine choke nexus General Discussion 3 04-01-2007 1:54 PM
929 hard shifting @ high engine speed oldblade Honda FireBlade 4 10-17-2006 11:58 AM
A gun was pulled on me. colryn Off-Topic 69 07-20-2004 3:17 PM
I got pulled over for...... crazy-a General Discussion 33 01-12-2004 8:56 AM
I got pulled over! asiliat Off-Topic 5 09-28-2003 12:28 PM
