08 muffler hole - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 10-11-2009, 7:37 AM Thread Starter
08 muffler hole
I changed the oil and filter on my oil burning 08 Blade (10,000 kms) and was checking for leaks with the engine running when I felt pulses of exhaust gas from beneath the muffler. Crawled under the bike to see what was going on and was surprised to see what looks like a machined hole about 1/8th" diameter half way along the underside of the muffler. Am I alone or do they all have it? What's it for?
nickwood is offline
post #2 of 5 Old 10-11-2009, 10:46 AM
Re: 08 muffler hole
I don't know about the '08 but it's common practise to have drain holes at the low point of the exhaust sytem.
post #3 of 5 Old 10-11-2009, 1:06 PM Thread Starter
Re: 08 muffler hole
Ah so that's where all the oil goes. Cheers Bladeracer.
nickwood is offline
post #4 of 5 Old 10-11-2009, 2:27 PM
Reputation Power: 39
Re: 08 muffler hole
Well, hopefully your aren't putting enough oil through the exhaust to warrant a drain hole for it...the drain hole is for precipitation that builds up in the bike's exhaust so that the water doesn't just sit in there and rust your pipes
If at first you don't succeed, skydiving is not for you...
WyoJames is offline
post #5 of 5 Old 10-12-2009, 12:59 PM
Quoted: 2 Post(s)
Reputation Power: 11
Re: 08 muffler hole
no the hole is the engine oil overflow bypass!
seriously, checked it on mine, it is the same & it is most probably as blade racer suggested
bonjo is offline
Can this hole be fixed? flipsidenv Honda FireBlade 10 07-01-2009 4:13 PM
Am i an as*hole for doing this? FTP_929 General Discussion 11 06-13-2008 5:09 PM
Biggest A-hole I've ever come across... Pete Off-Topic 18 03-30-2005 2:55 PM
Fire in the hole!!! pdx954 Off-Topic 19 11-16-2004 2:08 PM
So where's the hole? Red Rider Honda FireBlade 3 08-19-2003 12:51 PM
