929 cylinder walls vs 954 - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 10-13-2009, 6:39 PM Thread Starter
Reputation Power: 11
are the 929 and 954 cylinder cases the same except for the 954's bored 1mm further?
im thinking of building a turbo motor and if the 929 cylinders are thicker it will be the better choice
brandont454 is offline
post #2 of 6 Old 10-14-2009, 1:49 AM
Re: 929 cylinder walls vs 954
I think they are the same OD but have never been able to confirm it for sure. I have a 954 opened up if you have an open 929 we can compare.
If you're turboing it though, I wouldn't waste your money boring and replating as the extra 50cc is going to have a minimal effect when you add the turbo.
post #3 of 6 Old 10-14-2009, 3:08 PM Thread Starter
they wont be bored any, id just like to have the added insurance of a thicker cyl wall if im going to be increasing cylinder pressure quite a bit ( almost 1 bar)
post #4 of 6 Old 10-14-2009, 3:27 PM
I don't think there's much difference in strength as I've seen heaps more turboed 954's than 929's. Actually, I can only recall ever seeing one 929 turbo.
post #5 of 6 Old 10-14-2009, 7:39 PM
i have a 929 apart let me know how to check it so we can compare and keep it noted for future.
gsxrfxr is offline
post #6 of 6 Old 10-24-2009, 3:24 PM Thread Starter
you need a set of calipers to find the exact measurement between of the cyl wall
where to buy tachometer for two cylinder? grinster General Discussion 0 07-11-2009 10:43 AM
Cylinder not firing carp4 Honda FireBlade 26 08-06-2007 10:34 PM
Master Cylinder Chekman Honda FireBlade 8 02-02-2006 12:40 PM
Cylinder Problem JamesEarl15 General Discussion 4 05-03-2005 10:55 AM
Help... Key cylinder noise. Blueman Honda FireBlade 2 08-29-2004 1:26 AM
