954 Wont Crank - Honda Motorcycles - FireBlades.org
post #1 of 16 Old 10-14-2009, 8:24 PM Thread Starter
954 Wont Crank
So here is the issue. My 954 will not crank. When I turn the key to on fuel pump wont prime and the starter button doesnt work. the cluster lights up like it should and the battery is OK. I hot wired the starter and it cranked. The engine stop relay does not click either. I took apart the kill witch looks fine. Its behaving like the kill switch is off. It is not.
If it was a problem with bank angle sensor will the starter button work?
Any help would be great. Has anyone had these same problem?
CHOB is offline
post #2 of 16 Old 10-14-2009, 8:46 PM
Reputation Power: 78
Re: 954 Wont Crank
Have you shorted the connection in the killswitch, sorry I know you said its fine, but a visual inspection can lead to false conclusions.
Welcome to the forum!
BurtonF166 is offline
post #3 of 16 Old 10-14-2009, 8:48 PM Thread Starter
Re: 954 Wont Crank
Thanks a lot. I'll tie it off to be sure.
PS. Do you know what system controls both fuel pump and the starter?
CHOB is offline
post #4 of 16 Old 10-14-2009, 8:50 PM
Reputation Power: 25
Send a message via AIM to JohnnySpeed954
Re: 954 Wont Crank
Check your fuses. I know it sounds dumb but you would be surprised!
JohnnySpeed954 is offline
post #5 of 16 Old 10-14-2009, 8:53 PM
Re: 954 Wont Crank
Not sure which "killswitches" disengage the starter...
Kickstand switch?
Neutral?
post #6 of 16 Old 10-14-2009, 9:11 PM Thread Starter
Re: 954 Wont Crank
Kickstand switch?
Neutral?
They both do. but that doesn't explain the fuel pump. hrumph. It has to be a system that controls both the pump and the starter switch.
CHOB is offline
post #7 of 16 Old 10-14-2009, 9:12 PM Thread Starter
Re: 954 Wont Crank
done and done. thats totally what it sounds like but nothing there.
CHOB is offline
post #8 of 16 Old 10-14-2009, 9:15 PM
Re: 954 Wont Crank
Where is Cow Town anyways?
Colorado, Nebraska?
Whats the history of the bike?
post #9 of 16 Old 10-14-2009, 10:17 PM
Reputation Power: 12
Re: 954 Wont Crank
yeah mines doin the same wen i turn the key it wont prime either. it was runnung fine i went to move the bank angle sensor cuz i have a stunt shield and now it wont prime i reset the batery i keep the sensor level i checked fuse im gettin frustrated any help
BIGSEXY954RR is offline
post #10 of 16 Old 10-15-2009, 2:11 AM Thread Starter
Re: 954 Wont Crank
Colorado, Nebraska?
Calgary Canada. Yee Haw!
CHOB is offline
post #11 of 16 Old 10-15-2009, 10:16 PM
Reputation Power: 11
Re: 954 Wont Crank
i had that issue with my bike something came unpluged by that little box connected by the fairing stay
clarke83 is offline
post #12 of 16 Old 10-16-2009, 12:00 AM
Re: 954 Wont Crank
No magic answer, get a multimeter and a manual and start checking. Visual inspections are worthless unless it's just blatantly obvious.
unfetteredmight is offline
post #13 of 16 Old 10-16-2009, 4:35 AM
Re: 954 Wont Crank
That's the bank angle sensor.
post #14 of 16 Old 10-21-2009, 9:32 PM
Re: 954 Wont Crank
yeah it was my bank angle sensor i spliced the wires and connected the red and green cables and left the white seperate this byepassed the sensor and asa i turned thge key my pump primed and bam ma baby started
post #15 of 16 Old 10-21-2009, 11:06 PM
Reputation Power: 10
Re: 954 Wont Crank
the fuel pump wont prime if the killswitch is off everything else will light up
cbr954rrblade is offline
929 vs 954 crank JakeT Honda FireBlade 6 11-21-2011 6:50 PM
CBR929RR Will Not Crank CRD Honda FireBlade 5 03-14-2009 5:33 PM
Looking for an F4/F4i Crank JMart Wanted 0 08-13-2007 10:01 PM
WHY WONT THE CRANK CASE COME OFF!!! THICK&THIN=KID Honda FireBlade 2 01-18-2007 10:48 AM
929 won't crank deltwith Honda FireBlade 3 06-28-2006 7:22 PM
