954 03 does not start - Honda Motorcycles - FireBlades.org
post #1 of 23 Old 11-04-2009, 4:19 PM Thread Starter
Hy guys,
I have a little problem with my 03 954. I mounted USA wiring loom and ECU in
order to remove HISS ( European models have this circuit but USA model
not ) and key pack. All mounted ok, but I have problems with ignition, bike
does not start. I think that the problem is the right switch ( I used the
european one ) , 12v signal does not arrive, also exhaust-valve-servo does
not move.
Can anyone help me with the wires and their function ?
PS: Sorry for my bad english
pleon01a is offline
post #2 of 23 Old 11-04-2009, 4:22 PM
Re: 954 03 does not start
Originally Posted by pleon01a View Post
Hy guys,
not move.
You replaced the ignition switch as well?
The HTEV won't move if you can't start the bike. Or do you mean it won't move by hand either?
Do the dash and other lights work okay?
post #3 of 23 Old 11-05-2009, 3:20 AM Thread Starter
The ignition switch on the handlebar is from my original bike, I'm afraid
that this is the problem ... perhaps wires are not in the same place.
Dash works, neutral light is on and also red light near it is always on, if I
try to enter in "maintenance mode" using the black jack near battery pack,
nothing happens ...
pleon01a is offline
post #4 of 23 Old 11-05-2009, 3:33 AM
nothing happens ...
The MIL may be a code from the new ECU rather than a problem with your bike. Is the ECU from a Cali model perhaps?
post #5 of 23 Old 11-05-2009, 8:01 AM Thread Starter
Ups, I don't remember in which state I bought it, sorry
pleon01a is offline
post #6 of 23 Old 11-05-2009, 10:19 AM
The US ignition switch has a diode in it that will prevent the bike from starting so you'll need that for the US ECU.
post #7 of 23 Old 11-05-2009, 1:26 PM Thread Starter
Thanks bladeracer, u know if this diode is also present in CBR 1000 ignition
switch ?
Thanks, pietro
pleon01a is offline
post #8 of 23 Old 11-05-2009, 1:31 PM
switch ?
Thanks, pietro
Unfortunately I don't have wiring diagrams for the 1000RR.
If you search the forums you may find a way to circumvent the diode as I'm sure somebody has posted something about it.
post #9 of 23 Old 11-05-2009, 1:40 PM Thread Starter
Thank u very much! This is wonderful notice !
pleon01a is offline
post #10 of 23 Old 11-06-2009, 3:44 AM Thread Starter
Hy all, found 2 problem ... bank lean sensor kaput
and the evil pink wire disconnected ... now i have to
find a way to put 9v to the wire
pleon01a is offline
post #11 of 23 Old 11-15-2009, 11:29 AM Thread Starter
Me again, anyone have the 2003 954 wiring diagrams ( USA Model )
thanks
pleon01a is offline
post #12 of 23 Old 11-15-2009, 11:48 AM
Hopefully these are sufficiently readable.
929 954 wiring diagrams
929WiringDiagramUSCanada.jpg‎   929WiringDiagramEuropean.jpg‎   954WiringDiagramUSCanada.jpg‎   9542002WiringDiagramEuropean.jpg‎
9542003WiringDiagramEuropean.jpg‎
post #13 of 23 Old 11-15-2009, 12:14 PM
take the bank angle sensor off if you dont want to replace it...splice the red and green wire together let the white one alone. The pink wire can be jumped to one of the black wires coming off of your ignition or sotter a resistor in series on the pink wire it will work as well. Dont know the size(or remember) of the resistor but its the same as whats inside your ignition.
chasesdaddy01 is offline
post #14 of 23 Old 11-17-2009, 5:51 PM Thread Starter
Thanks to all ... daddy this trick in very useful!
blade this diagram are wonderful, do u write it yourself ?
Mine ECU is 38770-MCJ-A01 and use 954 usa wiring loom ( 3rd image )
It' s perfect!!!!
pleon01a is offline
post #15 of 23 Old 11-17-2009, 5:58 PM
It' s perfect!!!!
No, I just took photos of the Haynes manual :-)
01 F4I won't start Brian22 Honda CBR 600 1 06-12-2008 9:50 PM
'00 F4 - Won't Start, where do i start? cranks but doesnt fire. dunkd Honda CBR 600 7 07-30-2007 5:32 PM
F4i won't start HondaGalToo Honda CBR 600 5 07-23-2007 6:59 AM
cold start(how does your 954 start) JakeT Honda FireBlade 21 06-28-2005 11:01 PM
Don't know where to start. Fig Off-Topic 2 12-19-2004 7:59 AM
