954 rim in 1000rr forks - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 12-01-2009, 12:35 AM Thread Starter
i want to put a 954 rim in 1000rr forks will it fit? and will i have to change of the spacers or anything like that?
NEWMONIC is offline
post #2 of 7 Old 12-01-2009, 1:54 AM
Re: 954 rim in 1000rr forks
Nope, it bolts straight in.
1000RR discs are 10mm and 20mm smaller diameter though so it's best to use your 929/954 discs.
post #3 of 7 Old 12-01-2009, 7:46 AM Thread Starter
what yr 1000s are 10mm and what yrs are 20mm smaller ?
NEWMONIC is offline
post #4 of 7 Old 12-01-2009, 8:06 AM
'04/'05 are 310mm discs, '06/'07 are 320mm.
post #5 of 7 Old 12-02-2009, 1:47 AM Thread Starter
so if i was to run 04/05 1000rr forks and calipers on a 954 rim and discs, then id need 20mm spacers/risers for the calipers wouldnt i?
NEWMONIC is offline
post #6 of 7 Old 12-02-2009, 1:59 AM
It doesn't matter what wheel you run.
If you want to run 330mm 929/954 discs then you would need 20mm spacers for the radial caliper mounting bolts and 20mm longer bolts.
post #7 of 7 Old 12-02-2009, 2:14 AM Thread Starter
cool thanks for the help mate!
NEWMONIC is offline
1000rr Forks on my 929 babisgr Honda FireBlade 9 10-25-2009 2:46 AM
1000RR Forks buddha43 For Sale 0 10-10-2007 4:00 PM
1000RR Forks on an RC buddha43 Honda RC51 3 07-09-2007 5:56 AM
Will 1000RR Forks Fit alpine Honda FireBlade 7 02-02-2007 5:03 PM
1000RR forks for 954 forks??? eazenutz33 Honda FireBlade 2 01-13-2007 3:36 PM
