very high revs on cold start - Honda Motorcycles - FireBlades.org
 4Likes
post #1 of 39 Old 04-13-2010, 2:18 AM Thread Starter
Reputation Power: 11
hello folks....my 929 blade has started to rev up to 4500rpm on startup. It has always started and stayed at 2500rpm or so for a few mins then slowly reached temperature and ticked over at 1200rpm. It hasnt done this in the past even during the ice and snow we have had the last few months. 4500rpm sounds so loud at 5.30 am (when I set out to work). I have checked the obvious cables and checked for air leaks but all seems fine. It doesnt do it every time but maybe 7 out of 10 starts it revs very high....any ideas????
dave h
davrosxuk is offline
post #2 of 39 Old 04-13-2010, 4:09 PM
Reputation Power: 10
Re: very high revs on cold start
sound like the choke?
rr ray is offline
post #3 of 39 Old 04-13-2010, 4:54 PM Thread Starter
yeah. its fuel injection so the choke is automatic. I wonder if it could be failing somehow...I will have to check at the weekend (unless someone has any info meanwhile)
post #4 of 39 Old 04-13-2010, 11:46 PM
if you revv it while its warming up..that will happen..i think when its revved the starter valves move to far in and increase the cold start speed...i know if i do it to mine it does the same thing
ZeroKool929 is offline
post #5 of 39 Old 04-14-2010, 12:07 AM
Reputation Power: 77
ohh ohh
sounds like you guys have the same issue
A FIed bike can be revved while warming up, and it will return to its ~2500 rpm accelerated warm up.
BurtonF166 is offline
post #6 of 39 Old 04-14-2010, 12:18 AM
it is pissed that it has to be up at 5:30am to go to work....I don't blame it for getting loud with you!!
maybe the stepper motor/auto choke is acting up???
HRC RC51 is offline
post #7 of 39 Old 04-14-2010, 1:54 AM Thread Starter
lol....yeah getting started at 5.30 isnt very sociable. Thanks for the answers everyone....Zerokool...mine starts ok, ticks over at the normal 2500rpm warm up speed for maybe 20-30 seconds then shoots up to 4500-5000rpm without me touching the throttle at all...then settles again about 30 seconds later????
post #8 of 39 Old 04-14-2010, 5:07 AM
Reputation Power: 36
Something must be wrong with the fast idle control. There is a wax pellet that expands and contracts to control air bypassing the throttle plates that must be allowing too much air. Time to check a manual and I think it can be adjusted somewhat. It may need replacing. Strange because usually they don't allow the engine to come to proper hot idle when they are bad. They hang open.
denzee is offline
post #9 of 39 Old 04-15-2010, 10:19 PM
Ya mine idle will only hang if i crack the throttle..it seems to be different that what your describing.. I know there is a warning in the manuel that states not to open the butterflys fully then shut them with out the cables attached..not 100% sure why..but maybe it hits the fast idle was unit and causes it to be out of wack..also you can remove the actual starter valves and clean them..theres a procedre to do so..and you def not want to use carb cleaner b/c of the inner coating..they recommend compressed air for the bores..maybe they are sticking.. but its wierd how your idle jumps back up without actually giving throttle..your sure you didnt damage the coating with in the tbis? around the butterflys? its black and looks just like carbon build up..it goes slightly above and below the butterflys..
post #10 of 39 Old 04-16-2010, 3:07 PM Thread Starter
I will check the throttle/butterflies tommorrow (saturday)..It hasnt done it the last couple of times that I,ve started it which is typical when you are ready to strip it down and sort it LOL....thanks for the replies ZeroKool
post #11 of 39 Old 04-16-2010, 11:11 PM
no prob! let us know what you find
post #12 of 39 Old 01-02-2019, 12:57 PM
Quoted: 3 Post(s)
hi did you ever get this sorted on your bike mines does the same never used to start from cold starts as normal after 20 seconds or so goes up to 45000-5000 then after 30 seconds ish drops back to normal
gav001 is offline
post #13 of 39 Old 01-02-2019, 1:30 PM
MrPickwick's Avatar
Quoted: 479 Post(s)
Reputation Power: 25
Nearly 9 years ago that post Gav, what is your problem in detail
MrPickwick is offline
post #14 of 39 Old 01-02-2019, 2:54 PM
Quoted: 3 Post(s)
yes mate did see that it was old i have a 929 first of fi ones road it all summer no problems now when you start from cold it starts as normal goes to about 2500rpm as should cos of choke after 20 seconds or so it pops upto 5000rpm stays there for 30 seconds or so then drops back down to 2500 after couple mins goes to normal idel when starting to warm. i donot touch throttle ust key in turn on hit button and leave
gav001 is offline
post #15 of 39 Old 01-02-2019, 3:01 PM
MrPickwick's Avatar
Quoted: 479 Post(s)
Is it spitting out any codes? can you check out the 4 sensors for proper working, MAP , ECT, TPS and IAT as these work with the ECU for a good start up, and have you changed the coolant lately?
Knocking or tapping sound in high revs Frustrated400 Honda CBR400RR 11 03-23-2011 9:22 AM
High revs from cold banana custard Honda FireBlade 12 03-27-2010 1:46 PM
holding back at high revs pls help bencbr Honda CBR400RR 18 11-08-2008 1:16 PM
Cold Start mxman87 Honda RC51 6 07-31-2008 10:21 PM
Cold start BurnsToughFord Honda FireBlade 10 11-28-2007 10:22 AM
