520 chain or 530? - Honda Motorcycles - FireBlades.org
post #1 of 10 Old 05-18-2010, 9:44 PM Thread Starter
520 chain or 530?
What is the diffrence in a 530 chain and 520? Im going to be ordering a new chain and sprocket and i was wanting to know what the diffrence was on those two! Also any adivise on a certain chain or sprocket would be nice> Thanks hondabro
hondabro954 is offline
post #2 of 10 Old 05-19-2010, 12:51 AM
Re: 520 chain or 530?
Look at this link. A 520 is narrower, and therefore lighter. However, there will be less area on the rollers taking the force, so they will wear slightly faster. I'm not sure what the weight difference is. Compare the tensile strength of the different chain, the higher the better. I just bought a DID x-ring, haven't installed it yet.
For sprockets, that depends on what you are looking for. Front sprockets are pretty much all the same. Rear sprockets, you can go with steel or aluminum. If you go aluminum, make sure you get a hard anodized one. If it isn't anodized, it will wear VERY fast. If you are diligent with chain maintenance, a hard anodized sprocket can easily last 8000 miles. Steel will last longer, but are slightly heavier. Would you notice the performance difference between steel and aluminum, probably not. I just bought one from Supersprox. It has a aluminum center and steel teeth, maybe the best of both worlds. Looks the business too.
Hope this helps a bit.
520/530 Chain Identification - CycleChaos
Skater! is offline
post #3 of 10 Old 05-19-2010, 11:27 AM
good explanation skater. unless you are going to be an avid track rider i wouldn't bother with a 520 conversion. stick with the 530 for strength and wear
ldavis is offline
post #4 of 10 Old 05-19-2010, 12:14 PM
Reputation Power: 36
denzee is offline
post #5 of 10 Old 05-19-2010, 1:40 PM
i have a RK 520 coversion kit on mine and it has held up well,seems to spool up a little faster by the seat of the pants o meter,just less weight to move
overholt13 is offline
post #6 of 10 Old 05-19-2010, 11:17 PM
Reputation Power: 12
520 is a good set up..went to a regina kit awhile back..no issues..slightly less weight...just remember 530 sprockets wont fit a 520 chain..plus I think there a bit more choices for gearing
ZeroKool929 is offline
post #7 of 10 Old 05-19-2010, 11:34 PM Thread Starter
Thanks for the Info, also i didnt say im riding on a 02 cbr954rr. i love the bike!
Do any of you guys know what the stock chain size was? 520 or 530
Thanks again> hondabro
post #8 of 10 Old 05-19-2010, 11:56 PM
stock is 530
a 520 -1 +2 conversion is usually good for noticeable difference
Trendkiller is offline
post #9 of 10 Old 05-20-2010, 1:18 AM
Hondabro - I have a 02 954rr as well. I did a 520 conversion (RK X chain and Vortex sprockets) with -1 in front and +2 in the rear aluminum. I lost some top end but I don't spend much time there on the public highways... On the flip side I gained some OMG acceleration off the line and through every gear.
It really depends on what kind of riding you are going to do and how much you want to spend or how often you want to spend it. Pay attention to what they said up top, it will wear out faster. However, the theory is lighter being better. That is to say, the engine uses less power turning lighter chain and sprockets so the power saved is transmitted to the pavement vs being lost turning heavier chains and sprockets.
Also keep in mind that changing the teeth on your sprockets will also throw off your speedo, but as luck would have it they make a device to correct that.
Cheers.
Mhans is offline
post #10 of 10 Old 05-20-2010, 8:52 PM
Just went back to 530 myself actually. 520 does add a 'hair' of performance but nothing you can't get back with a gear change. I just got tired of replacing chains and (alu) sprockets with every back tire. Depends how you ride I guess.
RRFireblade is offline
Standard chain type and chain link??? steppinlevels Honda CBR400RR 1 04-20-2010 4:01 PM
Cam Chain / Timing Chain Part no. King Kenny Honda FireBlade 2 05-15-2008 8:52 PM
Chain lube or chain wax? WCRSX Honda FireBlade 31 07-28-2006 7:30 PM
Well, if SYKOTYK is Chain Jr., and Chain is Chain, then I guess I'm Chain Sr. ConqSoft General Discussion 120 05-07-2005 10:12 AM
