'02 954RR fork problem - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 05-21-2010, 3:33 PM Thread Starter
Hi folks, I need help with my '02 954RR and this seems the best place to get it. I have a leak on the left fork from wheelies, stoppies etc. Bought new seals and replaced one so far without a problem. On assembly though, when I put the allen-bolt into the fork damper through the bottom of the fork, it turns at finger pressure but nowhere near 25 ft lbs. I've used a makeshift damper holder to keep the internal parts from spinning with the bolt but now it won't even come back out to see what the problem is. Yes, I made sure the centering cap was installed before I slid the assembly in place. It's like the bolt went all the way through the threaded portion and out the other side. I can't tighten or remove the bolt now so I'm dead in the water. Please tell me this is a stupid mistake that is easy to correct.
Ramjet-954RR is offline
post #2 of 7 Old 05-21-2010, 11:30 PM
Re: '02 954RR fork problem
Is this with the spring and fork cap installed?
Have you tried a rattle gun?
post #3 of 7 Old 05-22-2010, 9:47 AM Thread Starter
No, this is without the spring and cap installed. The manual says it should be torqued to 25 Ft/lbs before putting in the oil, spring, etc. The Damper is "attached" to the bolt but it won't tighten at all. It spins with the bolt unless held still but I can't tighten or remove it now. The bolt originally went in finger tight and now just spins. I'm thinking of having the bolt drilled out, removing the Damper and seeing just what happened; but if the bolt is inside the Damper, how can I remove it?
post #4 of 7 Old 05-22-2010, 10:00 AM
I never torque the damper rod bolt up until after everything is together.
That way the spring pressure holds it in place and it tightens up just fine.
I'd try that first before looking at trying to get it out.
post #5 of 7 Old 05-22-2010, 11:42 AM Thread Starter
I reassembled the entire shock minus the oil and tried it again; same thing. I went ahead and disassembled the right shock to check for 'dumb errors' and found I had put it back together correctly with the exception of the oil seal. It was installed upside down from normal since I followed the manual instead of my memory. Note to others: the written side of the oil seal does NOT face up; have it face the axle, not the handlebars. I still have a spinning allen bolt that will not tighten up or come out. BTW, the right side tightened up like a charm. I also found out the bolt CANNOT thread all the way through the Damper like I thought had happened since it tapers down to a small hole. All I can think of is the end of the Damper came loose from the housing and is turning inside it.
post #6 of 7 Old 05-22-2010, 11:48 AM
It's not a shock absorber, it's a telescopic fork.
Towards the axle is "up" - unless you've found a way of keeping the oil in the fork with the fork up the right way?
If you still can't tighten or loosen the bolt I can only suggest it's stripped?
Try a rattle gun to remove it.
post #7 of 7 Old 05-22-2010, 2:59 PM Thread Starter
Problem fixed; a friend at the Honda shop hit it with his air-wrench and handed it back to me. It seems the bolt just needed a little speed to turn it on, just like me. Thanks for your help and next time, I'll know to look into the directions closer before using the tools.
Tags
954
Fork leaking problem PHARMER954 Honda FireBlade 11 05-05-2009 9:16 PM
Front fork problem drooger Honda FireBlade 6 04-05-2009 8:46 PM
F4i Front Fork Vibration Problem TheJackal Honda CBR 600 8 06-25-2007 9:24 PM
Fork Problem Mark024 Honda FireBlade 2 03-29-2004 10:37 AM
front fork sag problem DavidGS Honda FireBlade 4 10-03-2003 8:47 PM
