954 mods - Honda Motorcycles - FireBlades.org
post #1 of 38 Old 05-21-2010, 4:45 PM Thread Starter
954 mods
any suggestions on mods for the 954. i already have full akro racing system k&n filter power commander with custom map. makin 139/72 right now would like to hit 150. any suggestions on how to get there??
fbc954 is offline
post #2 of 38 Old 05-21-2010, 11:25 PM
Re: 954 mods
Start by replacing the K&N with an OEM filter.
Then cams would be a good bet.
post #3 of 38 Old 05-24-2010, 1:02 PM Thread Starter
Re: 954 mods
any specific cams in mind that would be good for everyday use? also what about lighter pistons? i have heard of guys changing these out before but cant find a website to buy them from. i also dont want to lose my everyday rider.
fbc954 is offline
post #4 of 38 Old 05-24-2010, 1:08 PM
Re: 954 mods
Email the various cam manufacturers and ask them what grinds they have.
Or you can have yours ground to suit your specific needs.
The 954 pistons are already very light so I can't see much to be gained from a complete engine tear down just for that.
How much mileage is on the engine?
post #5 of 38 Old 05-24-2010, 1:14 PM Thread Starter
Re: 954 mods
15K. always had all reg maint done
fbc954 is offline
post #6 of 38 Old 05-24-2010, 1:15 PM
Re: 954 mods
Then there's certainly no reason to be opening the engine up.
post #7 of 38 Old 05-24-2010, 1:30 PM Thread Starter
Re: 954 mods
well any other suggestions to squeeze out some more power
fbc954 is offline
post #8 of 38 Old 05-24-2010, 1:32 PM
Re: 954 mods
Cams, OEM filter and remap to suit.
post #9 of 38 Old 05-24-2010, 1:39 PM Thread Starter
Re: 954 mods
thanks for the help ill try getting some cam info. when i get my results ill be sure to post
fbc954 is offline
post #10 of 38 Old 05-26-2010, 6:22 AM Thread Starter
Re: 954 mods
ok did some more research and this is the setup im looking at:
port and polish head
webcams racing camshafts
wiseco high comp pistons (13.2)Complete CK kit includes piston, rings, wrist pin, circlips, gaskets and sleeve
Camshaft Profiles:
VALVE
LIFT
DURATION
DURATION
@ 0.050"
GRIND
NUMBER
PART
NUMBERS
OPTIONS
QTY
PURCHASE
.360/.360
266/270
244/246
297/116
Regrind
57-420
$427.00
Performance profile to increase overall performance. Cam has a reduced base circle. Use F4 factory shims for adjustment. Requires High Compression Piston, and Exhaust System. Price Per Set (2).
Hardweld
N/A
New Cam
N/A
Other Products:
Cam Gear, Adjustable
CG-H08
$65.00
is there anything else i need besides good tuning? what kind of gains would i be looking at?
fbc954 is offline
post #11 of 38 Old 05-26-2010, 6:26 AM Thread Starter
Re: 954 mods
....that didnt turn out like it was supposed to....
fbc954 is offline
post #12 of 38 Old 05-26-2010, 6:33 AM
Re: 954 mods
Camshaft Profiles:
VALVE
LIFT
DURATION
DURATION
@ 0.050"
GRIND
NUMBER
PART
NUMBERS
OPTIONS
QTY
PURCHASE
.360/.360
266/270
244/246
297/116
Regrind
57-420
$427.00
Hardweld
N/A
New Cam
N/A
Other Products:
CG-H08
$65.00
What are the sleeves you list with the piston kit?
I would think that'd get you pretty close to the 150hp you're chasing. The high-compression pistons and head work won't get you much - especially considering the cost of stripping the engine to install them. I'd suggest just dropping the cams in and see how you like those before pulling the head or stripping the engine.
post #13 of 38 Old 05-26-2010, 6:41 AM
Re: 954 mods
Don't forget to add the cost of sixteen new shims for the cams.
About $100 for the set.
post #14 of 38 Old 05-27-2010, 5:59 PM
Re: 954 mods
What is wrong with the K&N filters? This is the 2nd time in 2 days I have heard about this. (Other guy was talking about getting dirt in carbs with them) Seems like a sure bet that the higher flow would give an increase in performance.
robster1213 is offline
post #15 of 38 Old 05-27-2010, 6:55 PM
Reputation Power: 12
Re: 954 mods
I would love to know what gains you get after changing just the cams. if its significant, then i will do the same.
frank is offline
02' 954 mods sportmotob Honda FireBlade 5 01-04-2009 4:59 AM
06 mods blackdog Honda Naked Sportbikes 9 08-25-2007 6:53 AM
new mods CBR929RE Off-Topic 23 02-20-2006 9:00 PM
Help after mods umac13 Honda FireBlade 6 03-05-2005 10:37 PM
What Mods are you Going to do? hokoyo Australia 32 05-27-2004 8:27 PM
