954 Runs like garbage and dies - Honda Motorcycles - FireBlades.org
post #1 of 24 Old 06-22-2010, 7:21 PM Thread Starter
I am having problems with my 954. I left it sitting all winter and now want to enjoy the nice weather. Battery was dead so i tried to jump start it and it starts after lots of cranking on the starter but runs like garbage. Anytime you give it any gas it boggs down and dies. and if u let it idle it will die with in a couple of min. after reading on this forum i thought i have a faulty TPS senor or FPR. I replaced the whole throttle body set including injectors, FPR and TPS and vaccum lines etc.(i bought them used). I checked and cleaned the plugs. and still having the same problem. I have the airbox still off trying to troubleshoot it. Whats next to replace or test? Any input would appreciated!!
mcgee.cody is offline
post #2 of 24 Old 06-22-2010, 7:27 PM
Reputation Power: 78
Re: 954 Runs like garbage and dies
Its surely bad gas.
BurtonF166 is offline
post #3 of 24 Old 06-22-2010, 7:38 PM
If you replaced the throttle bodies you will likely need to have them synched to your motor. This is done using a sychronizing vacum tool. Also make sure you charge your battery all the way. Although if the battery was the problem you should not notice it until you disconect the jumpers. Last just like he said earlier replace the gas and maybe add some seafoam to the gas. Good luck!
honda50 is offline
post #4 of 24 Old 06-22-2010, 7:43 PM Thread Starter
I have replaced the gas and ran a can of seafoam with it. I have been jump starting tHe bike with an extra battery I have in my garage. Sync the tb with the motor by checking the vaccum pressure at each cylinder?
post #5 of 24 Old 06-22-2010, 7:56 PM
Did you actually check the FPR?
Did you drain the old fuel and replace it with fresh stuff?
post #6 of 24 Old 06-22-2010, 7:56 PM
With the airbox off, youll get a fault code for the IAT sensor which can cause issues
post #7 of 24 Old 06-22-2010, 8:09 PM
Also since you where pulling on and off the vacum lines make sure none of them are cracked or leaking. When you start it, does it stumble up high or just down low in the rpm range? You do synch the throttle bodies with the engine running by connecting a vacum hydrometer to each cylinder all at the same time and synching them to match.
honda50 is offline
post #8 of 24 Old 06-22-2010, 8:23 PM Thread Starter
I pulled the vaccum line off the side of the fpr and no gas is coming out. I drained all the gas out and put new gas and seafoam in the tank. I have not synced the tb. I will read more info on it and go buy a vaccum guage. The iat sensor is pluged in just not in the air box. I have no error codes.
post #9 of 24 Old 06-22-2010, 8:33 PM Thread Starter
I looked at all the vaccum lines and they look fine, no cracks or anything.
I lost the key to the bike, so i pulled off the bottom of the ignition switch and am using that to start the bike. the diode on it was broke so i sodered a 2000 ohm resistor on the bottom of it.(Pink wire). i dont this will have anything to do with it running like crap but thought i should give u all the info.
post #10 of 24 Old 06-22-2010, 8:52 PM
Reputation Power: 17
Originally Posted by BurtonF166 View Post
Its surely bad gas.
rokitt51 is offline
post #11 of 24 Old 06-22-2010, 9:38 PM Thread Starter
I'll try gas again. I'll go get some 93 and fill it up. I'll post results
post #12 of 24 Old 06-23-2010, 2:32 AM Thread Starter
Fresh tank of gas no help. Started it, idle, die. Did it a couple times. Checked resistance on the tps, good. Pulled the sparkplugs seem fine but will post pics of them when I'm not on my phone. From what I've read the bike has to be running to sync the tb's. I can't get it to idle long enough to do that. Any other ideas?
post #13 of 24 Old 06-23-2010, 2:40 AM
unless the TBs have been messed with prior, there should not be a sync issue.
At what rpm is it idling?
post #14 of 24 Old 06-23-2010, 3:15 AM Thread Starter
Idle is at about 1k to 1.5k. I have played with the idle adjuster. Even if I set the idle higher it still does the same thing. Very hard to start, rough idle for a min then dies. Bad ecu??
post #15 of 24 Old 06-23-2010, 3:22 AM
Sounds right.
Do you have a power commander?
ECU would be the very last thing to check, especially if it just sat for 6 months.
Did you by chance hook up some of the injectors on the new TBs up incorrectly?
Bike runs fine and then dies after a while ecd2004 Honda CBR 600 21 04-17-2017 8:55 AM
1995 900RR Runs Good Then Runs Bad eetchickn General Discussion 2 03-17-2009 9:57 PM
93 cbr 600 starts hard then runs and dies help honda4life251 Honda CBR 600 3 05-23-2008 9:01 PM
bike runs fine,dies and won't restart CBR629 Honda RC51 1 05-15-2008 10:07 PM
Garbage Can Surprise Chain Off-Topic 3 03-12-2005 6:16 PM
