Screw in my tire....patch? - Honda Motorcycles - FireBlades.org
post #1 of 11 Old 08-03-2010, 2:09 AM Thread Starter
2 questions really.
1. Picked up a screw in my tire today...tire still has at least 1000 miles left on it, can I patch a tire if its in the center?, seems to be mix opinions on if its a good idea.
2. If I choose to replace...can I mount a 200 rear?
temperedtim929 is offline
post #2 of 11 Old 08-03-2010, 2:25 AM
Re: Screw in my tire....patch?
Originally Posted by temperedtim929 View Post
2 questions really.
1. If it's not leaking just leave the screw in there. If it is leaking then you would have to patch it or plug it. I'd have to see it to know for sure but I can't see any problem with plugging it. If that doesn't work, then you'd have to remove the tyre and patch it.
2. Sure.
post #3 of 11 Old 08-03-2010, 2:29 AM Thread Starter
a 200 rear gonna slow me down in the turns?
post #4 of 11 Old 08-03-2010, 2:37 AM
It won't slow you down but I would expect it to take a bit more effort to turn the bike. You'd probably gain a little cornering clearance as well but I've never run wider than 195, and that was a 70% profile.
post #5 of 11 Old 08-03-2010, 3:27 AM
LoopyLee's Avatar
Reputation Power: 144
Send a message via MSN to LoopyLee Send a message via Skype™ to LoopyLee
2 questions really.
I had one plugged where the screw went in dead centre and it was just fine. The tyre was still going strong at 7500 miles Make sure you get it done at a garage for the best job. If you try somewhere and they say you need a new tyre try somewhere else as some places will only put on a new tyre as they get more money from that sale..
What you leave behind is not what is engraved on stone monuments, but what is woven into the lives of others - Pericles
Blade Rider
LoopyLee is offline
post #6 of 11 Old 08-03-2010, 3:45 AM
Quoted: 2 Post(s)
Reputation Power: 31
1. plug the rear, dont plug the front. That was the advise I was always given. I have had the rear done a few times.
2. Not a clue! lol
good luck
God had fire and Brimstone......I've got a FireBlade on Bridgestones!
Milzy is offline
post #7 of 11 Old 08-03-2010, 5:05 PM
Reputation Power: 12
2 questions really.
Have a read of the end of my thread on the same topic. I would say you can definitely plug it without worry. I did a full track day on a plugged rear tyre and had no issues.
https://www.fireblades.org/forums/hon...corsa-3-a.html
SteveGreen27 is offline
post #8 of 11 Old 08-03-2010, 7:46 PM
Quoted: 99 Post(s)
Reputation Power: 231
Plug it !! no worries
The mind is a funny thing
Jazzy's Blog
jazzy is offline
post #9 of 11 Old 08-04-2010, 12:56 AM
Send a message via AIM to MTXMUGEN
i would plug it and forget it. picked up a nice metal bit slightly off center in my tire a while back. pluged it and watched it for a while. looked good so i proceeded to run the bike hard after and have yet to have an issue 5000 miles later.
as long as the repair is made close to center i wouldent worry..a front tire or near the edge of a rear is a different story
MTXMUGEN is offline
post #10 of 11 Old 08-04-2010, 2:19 AM
Reputation Power: 59
Throwing a 200 rear on, will change the curve of the tire. It will change the way it corners, maybe not drastically but it will be there. Also if the front is the stock size, its tire profile will be different. From what I understand from racers is that the bike will be almost awkward in the corners because of it
Krazed is offline
post #11 of 11 Old 08-04-2010, 2:25 AM
Simply replacing a worn out tyre with a new one of the same profile will also make the bike steer and feel differently though.
There's only one way to know if you'll like it or hate it and that's to try it yourself.
Would you plug/patch a rear tire? drewpy General Discussion 42 10-24-2007 9:09 AM
Patch your Microsoft PC's/servers! ND4SPD Off-Topic 7 08-12-2006 7:40 PM
Patch panels BDA116 Off-Topic 3 03-12-2005 11:41 AM
jacket patch (pic) CBR929RE Off-Topic 3 11-02-2004 10:01 PM
Got my Fireblades patch today. Now what? CBRjack General Discussion 5 03-13-2004 2:51 PM
