929 Power Commander on 954 - Honda Motorcycles - FireBlades.org
post #1 of 11 Old 01-20-2004, 2:32 PM Thread Starter
Send a message via AIM to int76 Send a message via Yahoo to int76
Will a power commander from a 929 work on a 954? thanks justin
int76 is offline
post #2 of 11 Old 01-20-2004, 4:46 PM
Re: 929 Power Commander on 954
Yes, it will.
HondaGal is offline
post #3 of 11 Old 01-20-2004, 4:53 PM
It will only except 929 maps though. You'll have to load a 929 map then modify it (copy/paste will work) then you can upload it.
Cowboy is offline
post #4 of 11 Old 01-21-2004, 12:51 AM
Reputation Power: 23
cowboy is correct, give that man a prize
ratter is offline
post #5 of 11 Old 01-21-2004, 2:03 AM
And of course the major difference is the 929 model only allows upto a 45% change in fuel whilst the 954 model allows upto 100%.
Doubt that's a factor.
Magic
magic is offline
post #6 of 11 Old 03-13-2006, 9:00 PM
ok now that weve said the 929 power commander will work on my 954 will it be worth it to install it will it make that much of a difference is it worth the trouble
out ride you is offline
post #7 of 11 Old 03-13-2006, 9:14 PM
Dont waste the time or money unless you have a full system
954WRECKER is offline
post #8 of 11 Old 03-13-2006, 9:18 PM
well i do have an exhaust system and the power comander was free so the only thing i have to invest is a little time but will it make that much of a diff. will i be able to notice a change in performance
post #9 of 11 Old 03-13-2006, 9:38 PM
from what ive heard if you have a full system and a really good map then you will notice a difference. If you go to a dyno shop and get a custom map made for your bike you will really notice a difference.
post #10 of 11 Old 03-13-2006, 9:39 PM
Reputation Power: 15
When I put a PC3 onto my 929 it turned it into a whole new bike. Throttle response was improved as was fuel economy (by as much as 30Ks per tank).
I've kept the PC3 for installation on a 954 (which I'm intending to buy when I find a good one) and have spent a bit of time testing the copy and paste method for using a M104 PC3USB (929 version) instead of a M110 PC3USB (954 version) on a 954 and its a piece of cake if you use the standard Microsoft Windows Ctrl-C to copy and Ctrl-V buttons to paste.
Do the install, you wont regret it !
Spanky is offline
post #11 of 11 Old 03-13-2006, 10:15 PM
I use a PC3 on the 954 for ridability not for pure performance improvements.
Considering 100% of my riding is street and mostly commuting :-( I can't see how to use 100% of standard power let alone any increase. What I did find I could use was a smoother on/off throttle response at lower rpm. Anything under about 4Krpm (from memory) was very on/off when trailing the throttle, by using the PC to modify the fuel map has made the throttle much smoother at those lower revs.
Overall the use has increased my enjoyment and that's what it's all about.
Magic.
magic is offline
929 or 954?  Should have kept... larddog954 Honda FireBlade 48 01-05-2017 6:00 PM
954 shock for 929?, other "better" OEM? 2bitsamile Honda FireBlade 2 12-01-2003 7:36 PM
929 forks fit on a 954??? synrrgy Honda FireBlade 4 12-01-2003 7:27 PM
954 headlight fit the 929? AfterShock Honda FireBlade 6 07-17-2003 12:20 PM
