929 clip-ons - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 01-21-2004, 5:29 PM Thread Starter
Ice
929 clip-ons
Is there anyway to lower the stock clip-ons
Ice is offline
post #2 of 8 Old 01-21-2004, 5:55 PM
Re: 929 clip-ons
Edit: Skip what I said..just read the next by post cowboy.
I'm not sure what in the hell I was thinking of....wrong tabs, they have nothing to do with the vertical adjustment.
not very easily. I think you might be able to remove/grid the 'pins or tabs' that stick out of the stock clips and fit into some holes in the forks. I would just buy some aftermarket clipons. I have vortex on mine (50mm for 929/954)....I love them. but they are not for the daily commutter or typical street rider.
IM000007.JPG‎
02FBlade is offline
post #3 of 8 Old 01-21-2004, 7:18 PM
Re: 929 clip-ons
You have to drop the forks a few inches in the triple clamps to get the clip-ons up high enough to clear the clip that holds them up. Remove the clip, reinstall the forks in the clamps, then you can lower the clip-ons a little (no lower than where the diameter of the tubes is reduced.
Cowboy is offline
post #4 of 8 Old 01-21-2004, 11:41 PM Thread Starter
Ice
Re: 929 clip-ons
So does everyone usually lower or raise the clip-ons on the 929? I feel as if my sits to high.
Ice is offline
post #5 of 8 Old 01-22-2004, 9:45 AM
Re: 929 clip-ons
Typically lower them if your a track rider and raise them if your a sport tourer....not sure if they make anything to raise them.
02FBlade is offline
post #6 of 8 Old 01-22-2004, 4:53 PM
Re: 929 clip-ons
I feel the footrests are in a very comfortable position for hwy riding. Only thing I do not like is the rubber on the top of the footrests which indicates a touring type bike & to me under wet conditions the foot can slip off compared to decent footrests with all metal & some teeth up for traction.
Smitty is offline
post #7 of 8 Old 01-23-2004, 6:22 PM
Re: 929 clip-ons
I'm considering these. They will go both lower and higher.
www.convertibars.com
Adrian
929Demon is offline
post #8 of 8 Old 01-24-2004, 12:27 AM
Re: 929 clip-ons
I lowered my stock clip-ons on my 954 for track use. The locator pin does not sit inside the triple clamps (undernieth). The pinch bolts are strong enough to keep the bars in place.
I initially wanted to replace the bars with vortex or similiar clip-ons because I thought they would be stronger and less expensive to fix in case of a crash. 2 years and 6 crashes later, I'm still using the same bars.
CherryPicker is offline
Interchangable Clip Ons? eliXXir Honda FireBlade 2 08-31-2003 10:26 PM
