my 929 from 2000 - Honda Motorcycles - FireBlades.org
post #1 of 42 Old 12-27-2010, 8:26 AM Thread Starter
my 929 from 2000
helloo people. my name is Alex,i am from Romania.
I have a question for you.A few days ago,i buy a 929 honda.its ok the engine sounds great,but i see a little problem:rpm varies from 1300 rpm to 1500 rpm.
my question is why?what's the problem? is due to spark plug,may be more serious problems?
my English is not so good and I hope you understand me.
thanks and waiting for your answer.
lexy is offline
post #2 of 42 Old 12-27-2010, 11:08 AM
Re: my 929 from 2000
Possibly air leaks around the intake manifolds or needs throttle body synchronisation.
I would do all the other maintenance first though to rule all of that out - air and fuel filters, oil and filter and spark plugs. I'd also check valve clearances while you're in there doing the plugs.
It's also worth checking the vacuum hose off the fuel pressure regulator is dry as they do fail.
Also check your battery voltage with the engine running as stators fail.
And check that the HTEV exhaust valve is correctly positioned either up, down or forward and not somewhere in between.
post #3 of 42 Old 12-27-2010, 2:16 PM Thread Starter
ok.I understand.I will keep in touch.
Today I started the engine and was behaving normally.
currently there is snow in my country and I can not go out with her.
lexy is offline
post #4 of 42 Old 12-29-2010, 9:18 AM Thread Starter
hello my friends,
i want to sey : today i start my honda and it worked ok.
not really understand why
lexy is offline
post #5 of 42 Old 12-29-2010, 4:14 PM
Quoted: 99 Post(s)
Reputation Power: 231
If you have the problem again take the advice from Bladeracer and check everything he listed. Good luck and to the .Org !
The mind is a funny thing
Jazzy's Blog
jazzy is offline
post #6 of 42 Old 12-30-2010, 3:53 AM Thread Starter
thanks ...
lexy is offline
post #7 of 42 Old 12-31-2010, 11:46 AM Thread Starter
Happy Birthday to everyone
What oil you recommend?I want to change the oil and do not know what to use.
lexy is offline
post #8 of 42 Old 12-31-2010, 3:10 PM
Any good semi-synthetic motorcycle oil will be fine.
post #9 of 42 Old 01-02-2011, 7:14 PM Thread Starter
l
electric fan not start
writes in the book, begins to open the thermostat to 82 degrees celsius and 83 to 90 is wide open but not me .....
lexy is offline
post #10 of 42 Old 01-02-2011, 10:19 PM
l
Have you run power directly to the fan to confirm it does actually work?
post #11 of 42 Old 01-03-2011, 9:24 AM Thread Starter
i will try
lexy is offline
post #12 of 42 Old 01-05-2011, 3:41 PM Thread Starter
hello hello my friends.
I have good news.Today I started my moto.I waited to warm and she started 81,82,83 degrees Celsius,the radiator was hot.the temperature drops to 82,81,80 degrees celsius and the radiator is hot hot .the termostat work. when the temperature was 104 degrees started the electric fan.and he wark.I am glad they work but problem with rpm varies still bothers me.
here in my country a set of spark plugs for my moto cost $ 150 and my money on a month of work $ 250.I buy and I change the spark plugs and if it goes bad...
my money goo nothing.
lexy is offline
post #13 of 42 Old 01-05-2011, 8:59 PM
Reputation Power: 10
Wow, spark plugs are expensive overthere. my idle jumps around a little too, especially when I turn up the idle to 3,000rpms for stunting. It doesn't effect my riding at all.
serious is offline
post #14 of 42 Old 01-25-2011, 4:20 AM Thread Starter
Helloo my friends.begin work:
I bought the oil, oil filter, brake fluid and coolant.
photo:
[IMG=http://img337.imageshack.us/img337/9100/25012011001.jpg][/IMG]
Uploaded with ImageShack.us
lexy is offline
post #15 of 42 Old 01-25-2011, 4:27 AM Thread Starter
sorry for low quality...
lexy is offline
2000, 929 Tienie Wanted 1 08-31-2010 5:11 AM
2000 CBR f4 zellx2004 General Discussion 0 03-26-2010 3:07 PM
01 929 $2000 sketchyboy For Sale 7 10-11-2009 9:51 PM
2000 929 for 4k??? rickyboyny Honda FireBlade 3 07-22-2007 10:21 AM
2000 CBR929RE Off-Topic 13 11-29-2004 2:16 PM
