taking out the 929 o2 sensor - Honda Motorcycles - FireBlades.org
post #1 of 22 Old 01-27-2004, 11:15 AM Thread Starter
I have heard that taking out the o2 sensor from the CA model will #1 make me lose a little weight and #2 add 1-2 HP has any one done this to their bike. I know I would need to buy some type of block off the reason I am asking is I want to put on a full system and I have to get rid of it the other problem is I really don't know how to properly disconnect it so it won't cause me problems with the way the bike runs. Any help would be appreciated
psycho929rr is offline
post #2 of 22 Old 01-27-2004, 11:19 AM
nedro's Avatar
Reputation Power: 27
Re: taking out the 929 o2 sensor
Ride Red
nedro is offline
post #3 of 22 Old 01-27-2004, 11:23 AM
ND4SPD's Avatar
Reputation Power: 50
Originally Posted by nedro
Got you a refill, scooch over, I wanna watch
ND4SPD is offline
post #4 of 22 Old 01-27-2004, 11:53 AM
EatnAsphalt's Avatar
Reputation Power: 19
You'll need either a resistor or you can buy a pre-made plug with the resistor (Dynojet sells one) to fool the ECU so you don't get the MIL light coming on all the time.
EatnAsphalt is offline
post #5 of 22 Old 01-27-2004, 12:05 PM
dB
When you get the full system also get the plug that EatnAsphalt mentioned, and also get a PCIII and get it mapped on a dyno.
Removing the O2 sensor before then would be a waste of time, IMO. The weight savings would be roughly equivalent to having regular vs. supersize fries for lunch, and I seriously doubt you'd notice a power gain that was anywhere near proportional to the drop in fuel mileage you'd get. My $.02.
dB is offline
post #6 of 22 Old 01-27-2004, 2:02 PM
Removing the O2 sensor without installing a PCIII will only make the bike run way too rich at low throttle settings, and reduce your fuel mileage by about 20%.
Removing it from a stock CA bike will net no power gain, and the weight savings will be on the order of a few ounces.
Joel is offline
post #7 of 22 Old 01-27-2004, 2:02 PM
It kills your gas mileage (the bike runs even richer than normal), saves you *maybe* four ounces, and is not being used as intended. According to Dynojet, with whom I spoke last week on this very subject, the 02 sensor bypass is not intended as a stand-alone mod, only as part of the PC addition.
redcliffs is offline
post #8 of 22 Old 01-27-2004, 2:39 PM
Same thing I found out from them. I ran them anyway sans PC and guess what.. they were right. I'd leave it alone unless you install a system that requires you to remove it.
Holeshot is offline
post #9 of 22 Old 01-30-2004, 10:26 AM Thread Starter
Already have a PCIII and putting on a full arata from dan kyle. Dan if your out there do you have a map for these specific's
post #10 of 22 Old 01-30-2004, 9:56 PM Thread Starter
What is a web site where I can get this block off?
post #11 of 22 Old 01-31-2004, 1:31 PM
http://www.powercommander.com/buynowacc.shtml
scroll down the page
Yes, Dan will provide a map for you, just ask him when you buy the Arata system.
zenblader is offline
post #12 of 22 Old 01-31-2004, 2:18 PM Thread Starter
thanks for that web site but it still says my FI light will come on and if there is a kit or something to get around that light coming on I would like to find it
post #13 of 22 Old 01-31-2004, 2:30 PM
It is my understanding that this kit will eliminate the FI light problem. Otherwise what would be the point of buying it? The last sentence in their description describes what would happen "if" you eliminated the sensor without using this item.
post #14 of 22 Old 01-31-2004, 7:17 PM
Sounds like somebody is missing the boat out there in "aftermarket land". Actually, I'd say they fell off the darn thing altogether.
The whole benefit of closed-loop EFI is the fact that a computer can monitor a number of issues at the same time. It can then make the BEST changes to all of the parameters over which it has control, with the result being the best power and/or economy for a given situation, as determined by the fuel/ignition map programmed into the ECU.
Should any significant sensor input be lost, the ECU drops into "limp-home" mode, which is open-loop, and which is totally reliant on a predetermined fuel/ignition map that makes MANY assumptions, and therefore sub-optimal (usually rich and spark-retarded) settings.
Reverting to open loop EFI is about as smart as reverting to carbs, since you lose the consideration for engine warm-up, and atmospheric conditions that the O2 sensor info provides. It might work OK for the conditions that it is designed in, but it can't possibly work as well in LA and Denver without map changes.
So these guys suggest that their conversion to open-loop EFI is better than remapping the closed loop system?? That's simply GARBAGE! It might be easier to do, and it might work in some small and well controlled environment that can't resemble the real world. I'd say that Barnum was right!!
BrianG is offline
post #15 of 22 Old 02-01-2004, 8:59 AM
My understanding is that on the bikes, the O2 sensor is used to trim fuel ratio to stoichiometric, i.e. 14.7:1, under part-throttle/cruise conditions only. This is NOT the best ratio for making best power. It is the best ratio for emissions/fuel economy. It would seem that most knowledgeable tuners will go for an air/fuel ratio of about 12.5:1 - 12.7:1 for best performance/power. Fuel mileage will go down, but who give a unless you bought your bike for commuting, in which case you probably wouldn't bother with something like a PCIII in the first place.
If you really want to make best power/performance with a closed-loop system, you'll need a "wide-band" O2 sensor and a computer designed to work with it, such as Accel's DFI, FAST Electronics' or MOTEC's ([HOMER] mmmmm.... MOTEC[/HOMER] ) system. These systems are programmable to feed back info from the wide-band O2 that will tell the ECU exactly what ratio is being measured at the sensor.
This is unlike the standard O2 sensor, which is really only designed to tell the ECU if the fuel ratio is richer or leaner than stoich -- not the actual air/fuel ratio. The standard systems, even on most cars, do go into open-loop under full-throttle conditions. This is because 14.7:1 is too lean for full-power and will cause detonation problems and along with them, possible melt down.
So, PCIII w/o O2 sensor IS a better system for performance applications than the stock ECU w/sensor, as it will allow an experienced tuner with a wide-band O2 sensor and a dyno to run the bike under simulated load conditions. The tuner can then make changes to the open-loop fuel table/map to adjust for best performance. Yes, if anything major changes, and this would include altitude, it might need to be remapped. I say "might", as our bikes incorporate a "MAP" (Manifold Air Pressure, IIRC) sensor, that can adjust for altitude changes, as the pressure readings will change with changes in altitude.
As always, YMMV. And if anybody else (OnTheEdge) more knowledgeable about EFI systems than myself would like to chime in to correct any of my possible errors, please do.
CanyonCarver is offline
Poor gas mileage on a 929 -- is no o2 sensor to blame? redcliffs Honda FireBlade 18 03-04-2004 7:00 PM
NEw 929 owner: Pipe? O2 Sensor? M4? Erwin8r Honda FireBlade 6 01-14-2004 3:00 PM
