CBR 1000RR 2009 ABS PROBLEM-HELP - Honda Motorcycles - FireBlades.org
post #1 of 12 Old 01-11-2011, 10:15 AM Thread Starter
Hi,if anyone know is it posible to block ABS and get manual brake that will work properly-if you ask me why than it is because my signal code-flashes are telling me that abs control unit is faulty and I would like to get manual brake back.
At the same time are brake calipers for not ABS model same by size for ABS MODEL and can I just change them to get manual brake.
thanks a lot
cbrforewer
cbrforewer is offline
post #2 of 12 Old 01-11-2011, 11:29 AM
Reputation Power: 41
Re: CBR 1000RR 2009 ABS PROBLEM-HELP
Can you lock up the rear brake to prove the ABS is not working ?
Plus, why not get the bike back to your dealer as it is pretty new still ?
Sometimes I wish I was a faster rider, but there's no heroes in the graveyard..............
splatty is offline
post #3 of 12 Old 01-11-2011, 11:55 AM Thread Starter
hi,well rear brake is working o.k but front one fade all the time I pres it,it is new but dealer in my country is far a way about 872miles ,and there is a lot snow now. bike has been layed down
post #4 of 12 Old 01-11-2011, 11:57 AM Thread Starter
rear brake locks complitly.
post #5 of 12 Old 01-12-2011, 5:05 PM
If the bike has been down the road, and the ABS is faulty, I would get it looked at by the dealer before you put many more miles on.
You need to know everything else is ok.
Sounds like a road trip with a trailer or van is required.
Stay safe
splatty is offline
post #6 of 12 Old 01-13-2011, 5:13 AM Thread Starter
well,I just started doing on my own and let see can I fix it by myself.I will let you know what is a score soon.
Regards.
post #7 of 12 Old 01-14-2011, 2:07 PM
If you have dropped the bike you can check for obvious things like broken wires to the abs sensors at the wheels, the pickups on the wheels are straight and the sensors mounts are not bent etc
I beleive you can disconnect the abs (Honda disconnected the system for journalists doing a comparison test) and have the brakes working as normal but I don't know how and honda won't make it common knowledge for safety reasons, law suits etc.
brym is offline
post #8 of 12 Old 01-14-2011, 2:14 PM
Reputation Power: 36
Generally when the ABS senses a problem with the system and sets the ABS light, it reverts back to normal braking which should function fine. You will just no longer have any ABS.
denzee is offline
post #9 of 12 Old 01-14-2011, 7:36 PM Thread Starter
hi,following the book signal code says faulty combined unit,because it is very expensive I replaced front brake hoses from ABS-my bike and placed front brake hoses from non ABS model,at same time I had blocked ABS regler on my bike and it has stoped air going into front valve,the rest of things are same. yellow light on instument or control meter table will be on but who cares the problem has been resolved. thank you.
post #10 of 12 Old 02-17-2011, 12:43 PM
if you pull fuse out on abs it works normal iv got the 09 abs to but iv took it all off and turned it in to a non abs !! the abs brakes are good i had no problem with it just got bored it was cheeper for me to turn it in to non abs bike than to part exchage it just about 1.500 to do it
johnk3 is offline
post #11 of 12 Old 02-17-2011, 1:18 PM
Bored with ABS, you mean it was that intrusive? I would have thought from what I read about the CBR system that even on the track it was quite useful.
Are you Troy Bayliss by chance?
denzee is offline
post #12 of 12 Old 02-18-2011, 5:21 PM
I'm confused John, why was it cheaper to turn it in to a non abs model. Did you sell the bits ?
From what I have read, I thought the ABS was supposed to be awesome.
Each to their own though mate
splatty is offline
CABS Problem 1000RR 2009???? FB1000inPA General Discussion 2 01-29-2014 8:51 AM
2009 1000RR Tri Color The Ripper Honda FireBlade 21 09-28-2010 6:06 AM
Akrapovic Evo Full Titanium System Fireblade 2009 PROBLEM?? PLEASE HELP DukeCBR2008 Honda FireBlade 3 04-05-2010 4:30 PM
2009 1000RR/Powercomander V problems easy6 Honda FireBlade 6 02-28-2010 7:51 PM
2009 CBR 1000RR For sale - Need the money UrHookUp Motorcycles For Sale 6 07-17-2009 6:00 PM
