HTEV - Honda Motorcycles - FireBlades.org
post #1 of 15 Old 01-28-2011, 9:09 AM Thread Starter
Reputation Power: 10
HTEV
I got my 954 dyno'd yesterday and custom mapped, it only has an akrapovic end can and bmc filter, the tuner was very impressed with it but reckons i should get rid of the htev and flapper in the airbox and he will adjust my map free of charge, he has the torque line very straight so its strong right through the revs, 139.3 bhp and 73.8 torque,
its a street bike so just want opinions of people who have done it and will i lose low end power thats worth talkin about, the tuner reckons i wont and my motor is very strong,
my htev is a bit rattly but servo and flapper are all working perfectly
levin is offline
post #2 of 15 Old 01-28-2011, 9:44 AM
Re: HTEV
Unplug your servo motor, turn the servo so the airbox flapper is open and go for a ride. The bike will be exactly as it is now above 8000rpm since the HTEV and flapper are open anyway.
The loss in midrange without the HTEV is noticeable but not significant - it is a litre-class bike after all.
post #3 of 15 Old 01-28-2011, 9:52 AM Thread Starter
Re: HTEV
cheers for the reply,
Ill try want you said but i think the tuner was goin to tweak the map for me so i wont be losing any midrange, would you do it or not???
Also is it best to have the htev welded fully open or remove it and cover with a plate
levin is offline
post #4 of 15 Old 01-28-2011, 9:57 AM
Re: HTEV
I had my HTEV open for a long time before I went with a full Akrapovic system.
Just leave it open. You can wire it in place if you're concerned about it moving but mine never did. No reason to weld it or remove it.
post #5 of 15 Old 01-28-2011, 10:10 AM Thread Starter
Re: HTEV
if i just unplug the servo it will show a warning light, thats why i was thinking of leaving the servo plugged in and stripping everything else out,
all the info i can find on the net is some say its better , some say not,
so im unsure if i should do it , i like the way the bike is now , very strong through the gears ,
its just the htev is a bit rattly and the tuner thinks i should do it,
yeh or neh???
and as i said its a street bike
levin is offline
post #6 of 15 Old 01-28-2011, 10:14 AM
Re: HTEV
yeh or neh???
My MIL has been on since '04 at least - it has no effect on the bike at all.
That's why I suggest you simply try it for yourself and see if you like it.
post #7 of 15 Old 01-28-2011, 10:20 AM Thread Starter
Re: HTEV
ok sound advice , ill give it a try and if i like it i can return the servo and stip everything out and if i dont just plug the servo back in
levin is offline
post #8 of 15 Old 01-29-2011, 7:21 PM
hfb
Re: HTEV
I've got a 929 and had it dyno'd with a custom map 139.04bhp and 71.57 torque standard air filter and leo vince end can. I've done the air filter flapper mod but left the htev valve working cos didn't like the mid range power I lost when locked open fully. had it locked in the position between 3000-8000rpm which was ok but lost low down power for riding round town etc. Would be interesting to look at your power curves on your chart if you could post it up. Which dyno was used by your tuner?
hfb is offline
post #9 of 15 Old 01-29-2011, 7:39 PM Thread Starter
Re: HTEV
the dyno was S14LCLI Dyno link to itDyno Centre
the tuner was very impressed with it and reckons alot of dyno's in the country are reading higher than his
dyno 954 001.jpg‎
levin is offline
post #10 of 15 Old 01-29-2011, 7:47 PM
hfb
Re: HTEV
Your power curve is very similar to mine with the slight dip at 7000rpm. are you using standard gearing.
hfb is offline
post #11 of 15 Old 01-29-2011, 8:01 PM Thread Starter
Re: HTEV
-1 on the front
levin is offline
post #12 of 15 Old 01-30-2011, 5:44 PM
hfb
Re: HTEV
same as me then, ok cheers.
hfb is offline
post #13 of 15 Old 01-30-2011, 8:41 PM
Reputation Power: 11
Send a message via Yahoo to letsride
Re: HTEV
If you have a power commander, then it will benefit from the htev valve removed or left wide open.
letsride is offline
post #14 of 15 Old 02-08-2011, 11:24 AM
Quoted: 11 Post(s)
Reputation Power: 57
Re: HTEV
Check out this site directly from Honda. This confirms the reasoning for the flapper and HTEV are environmental and have nothing to do with the performance of the motorcycle. I came across this site while searching the web this morning about the HTEV in Honda sportbike's.
Honda Worldwide | Noise Reduction
SOLD: 03 CBR954
backdoc is offline
post #15 of 15 Old 02-08-2011, 1:01 PM
Re: HTEV
Actually, it says they got improved engine performance in addition to less noise.
"For the CBR 1000RR, launched in the domestic market in April 2004, we achieved a level of noise reduction that is below the third noise regulation standards by using the following noise reduction technologies."
"The variable exhaust system that controls the diameter of the exhaust pipe according to driving condition is placed on the exhaust pipe manifold. This system improved output characteristics and achieved an excellent level of quietness as a result of the exhaust noise reduction."
"Variable intake system. By installing a variable intake system to control the intake opening at the front part of the duct, we improved output characteristics while significantly reducing intake noise."
Good find though. Nice to see official recognition that these do play a role in areas other than performance.
Htev eliminator SpookyjacK Honda FireBlade 51 04-11-2014 5:32 PM
06 1k HTEV Help drooger Honda FireBlade 2 05-03-2009 3:27 AM
htev ???? muddawg General Discussion 2 04-30-2009 2:06 PM
htev ? a_bomb30 Honda FireBlade 4 09-07-2006 10:53 PM
HTEV Cliff Honda FireBlade 14 05-22-2003 4:37 PM
