2006 blade w/ PCIII startup question.... - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 02-07-2011, 12:51 PM Thread Starter
hey guys i have a question. i installed the power commander and the map for my mods and when i first started it, she fired up and shut off. so i gave it a little throttle while i started it and it stayed running. my question is Can I change the map myself so that it gets enough fuel at start so i don't have to give it throttle. I know i would have to punch in numbers on the power commander software, but i have no clue about it and don't want to jack something up. thanks in advance for the help guys
adeezy9183 is offline
post #2 of 6 Old 02-07-2011, 12:54 PM Thread Starter
Re: 2006 blade w/ PCIII startup question....
Oh and if it makes any difference i'm using the two bros. slip on and aftermarket air filter map.
post #3 of 6 Old 02-10-2011, 2:30 PM Thread Starter
no one has had this problem before?
post #4 of 6 Old 02-11-2011, 11:14 AM
Reputation Power: 9
did u set ur throttle u do this wen the bike is not runing set at close and full open i hope this helps
manho315676 is offline
post #5 of 6 Old 02-16-2011, 8:11 AM Thread Starter
no i didn't. I got the power commander used so i didn't get any instructions or anything with it. how do i go about setting the throttle? my guess is you hook the pc up to the laptop and change it while the ignition is on and not running?
post #6 of 6 Old 02-17-2011, 8:27 AM
JM1
Here's a link to the user guide:-
http://www.powercommander.com/downlo...User_Guide.pdf
"To reset the throttle position click on “Power Commander Tools” and then select “Set Throttle Position. To reset both the closed and open throttle
positions, first make sure that the bike is communicating to the computer, then click on “Reset”. Twist the throttle wide open and release. Now click OK.
JM1 is offline
2006 CBR1000RR + Akrapovic Race + PCIII + Dyno results, low hp? hgate73 Aftermarket Perfomance Parts Reviews 5 11-13-2010 7:30 AM
Best oil for 2006 blade marty 29 Honda FireBlade 18 09-25-2010 12:59 PM
01 blade oil light on startup matt.k Honda FireBlade 5 09-09-2009 7:29 AM
Where to install PCIII USB on an '01 blade. theFooL Honda FireBlade 7 03-31-2009 9:04 AM
2006 Blade: What would you like to see? 929rrob Honda FireBlade 84 08-07-2005 11:11 AM
