2009/2010 standard exhausts - Honda Motorcycles - FireBlades.org
post #1 of 12 Old 02-07-2011, 6:12 PM Thread Starter
I've searched the forum, I'm sure the answer is here somewhere but I can't find it!
Will a standard 2010 exhaust (Silencer, containing cat and valve) fit a 2009 model without any modifications? That is, will it attach to the 2009 downpipes, is the cable for the valve the same type of attachment, the lambda sensor compatible, the bottom fairings on both bikes the same? Or are there any other problems I haven't thought off?
My bikes 'light' spot is slowly getting worse and it bugs me. If a 2010 exhaust became avail at the right price I'd consider changing it. Which leads me onto the next question ...
How successful is the new improved 2010 model exhaust in terms of maintaining its appearance?
Thanks
tullyhubbert is offline
post #2 of 12 Old 02-08-2011, 5:51 AM
Reputation Power: 41
Re: 2009/2010 standard exhausts
AFAIK the exhaust, including fitment, is unchanged on 2008-2010 models.
The only difference is the raised shield on the 2010 bike, which is probably only there to mask any whitening that may happen underneath.
When I requested a warranty replacement, I got a 2009 exhaust for my 2008 bike. My dealer told me that the exhaust is the same through all the models, there was only light cosmetic and engine changes. All the fairings are the same, just with subtle graphics changes
Sometimes I wish I was a faster rider, but there's no heroes in the graveyard..............
splatty is offline
post #3 of 12 Old 02-08-2011, 11:48 AM Thread Starter
Thanks Splatty
The 08 & 09 models are the same so that should have been ok, did the 09 replacement exhaust whiten?
The 10 model does indeed have the raised shield, but as it still seems to sit flush with the bodywork I thought maybe the exhaust itself was different to the 08/09 models.
Anyone know for sure?
post #4 of 12 Old 02-08-2011, 12:14 PM
I've never fitted the new exhaust mate. I went aftermarket and have kept it in a box for when I change the bike.
It does still look flush with the shield, but I'm sure it's the same.
I'll ask my dealer next time I pop in to be sure
splatty is offline
post #5 of 12 Old 02-08-2011, 1:01 PM
Quoted: 99 Post(s)
Reputation Power: 231
Is the main change to the 08-to date model Fireblade fitment of ABS..pretty much
The mind is a funny thing
Jazzy's Blog
jazzy is offline
post #6 of 12 Old 02-09-2011, 5:00 AM
Not really as it is still an option.
There was a minor engine change, flywheel I think, I'll have a look later.
The only changes were hangar, rear indicators. Cosmetic stuff like that.
splatty is offline
post #7 of 12 Old 02-09-2011, 5:06 AM
My memory..............
Bigger flywheels and a stronger crank with increased crankshaft inertia mass.
It is mentioned that the exhaust muffler is changed slightly, but it looks the same ?
Dealer question me thinks
splatty is offline
post #8 of 12 Old 02-09-2011, 5:43 AM
Quoted: 99 Post(s)
Some guys on another forum were saying it could do with a power boost, then I found this....https://www.fireblades.org/forums/bmw...-came-top.html
Jazzy's Blog
jazzy is offline
post #9 of 12 Old 02-15-2011, 5:43 PM Thread Starter
Well I think I must have had a bang on the head because I now have a new 2010 model exhaust which was removed from a new bike on its way. I'm hoping that cosmetically it will maintain its appearance much better than the 09 exhaust.
So I now have a carbon Yoshi R77 + PCV for sale, fill yer boots
https://www.fireblades.org/forums/for...liminator.html
post #10 of 12 Old 09-25-2012, 12:08 PM
Does anyone know if the heat shield on the 2010 onwards bikes is removable and can be fitted to a 2009, or is it all one piece with the exhaust?
repper is offline
post #11 of 12 Old 09-25-2012, 12:23 PM Thread Starter
Don't you just love it when an old thread is resurrected
Its removable but can't be fitted to a 2008/9 model exhaust as there are no brackets attached to them.
The 2010 model exhaust has been a great success, no discolouration to spoil the bikes looks. I paid around £120 all in for a new/used one of ebay, might be worth a look?
<edit> http://www.ebay.co.uk/itm/Honda-Cbr1...item4abc7d386b and there are a few more
post #12 of 12 Old 09-26-2012, 4:47 AM
Cheers, just the job.
repper is offline
2010 CBR 1000RR<C-ABS> and the 2010 Gsxr1000 TenHut Honda FireBlade 28 06-26-2011 6:56 PM
Will a 2009 CBR 1000RR swing arm fit a 2010 CBR 1000RR? whitarnold Honda FireBlade 6 02-02-2011 5:52 PM
2009 CBR1000rr Repsol aftermarket exhausts??? Keny-Boy Honda FireBlade 0 08-04-2010 3:58 PM
New 2010 Blade - high rise or under seat exhausts? Stuza Aftermarket Perfomance Parts Reviews 10 06-03-2010 3:29 PM
