96' 900RR Advice? - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 02-07-2011, 10:11 PM Thread Starter
96' 900RR Advice?
Alright, a couple questions.. Bike is not returning in heat or speed readings where it ought to on the display. RPMs however do show properly.
Secondly, I have an aftermarket exhaust for the bike and the diamater is too wide for the pipe. So I wonder, what do I get to fix this sot hat the can will slip on as it's supposed to? Am I missing a piece that should have come with the muffler?
AND finally... good place to get tires? these knobbies aren't too pretty.
CBRBoomer is offline
post #2 of 8 Old 02-08-2011, 2:46 AM
Re: 96' 900RR Advice?
What do you mean by heat and speed readings not being right?
post #3 of 8 Old 02-08-2011, 2:48 AM Thread Starter
Sorry, as in nothing at all... The needles do not move on the speedo, or engine temp. gauges.
post #4 of 8 Old 02-08-2011, 2:51 AM
Have you checked that the speed sensor and temp sensor are actually connected to the harness?
post #5 of 8 Old 02-08-2011, 2:54 AM Thread Starter
I did in fact, which is what I'm confused about. The wiring harness up to this point looks good too, and the sensors are connected. I see no faults in them they look good far as I can tell..
post #6 of 8 Old 02-08-2011, 3:18 AM
Reputation Power: 24
Maybe your gauges are fried. This happened to me once and I had to replace the whole cluster.
vfrman is offline
post #7 of 8 Old 03-10-2011, 10:04 PM
Reputation Power: 10
As VFR said gauges or maybe blown fuses
Hondasrule is offline
post #8 of 8 Old 03-11-2011, 2:24 PM
The tachometer is powered separately from the rest of the gauges. Since both your speedometer and temp gauge are not working correctly, it's unlikely to be the instrument cluster, you have a power or ground issue.
Check your fuses and if they check out then get a run of wire and run it from the Black/Brown wire where it attaches to the back of the cluster to battery positive. If the gauges work then, your Black/Brown wire is shorted or open in the harness.
If they still won't work, then run a wire from Green/Black on the cluster to battery ground. If they work, then you have an open in the Green/Black wire.
If neither works, then you would have to go deeper into the gauges with a meter and it would still most likely be repairable.
As for the exhaust, go to a muffler shop and have them fabricate a collar and weld it on.
Tires? http://www.motorcycle-superstore.com/
unfetteredmight is offline
Headlight conversion 95 900RR-98 900RR jamilrahman Honda FireBlade 10 11-18-2013 8:22 PM
1998-99 CBR 900RR face to 1996-1997 CBR 900RR mech5398 Honda FireBlade 26 02-04-2013 4:47 AM
Can I put a 1999 Cbr 900rr motor on a 1995 cbr 900rr frame? megan_miler707 Honda FireBlade 5 08-13-2012 10:42 PM
Can I put a 1999 Cbr 900rr motor on a 1995 cbr 900rr frame? megan_miler707 General Discussion 2 05-21-2009 10:14 PM
I need some advice! cbrbikerchick General Discussion 16 05-02-2004 12:20 PM
