954 breather pipes HELP - Honda Motorcycles - FireBlades.org
post #1 of 19 Old 02-09-2011, 4:00 PM Thread Starter
Reputation Power: 10
Hi
This is driving me insane. Had the tank and airbox of my 954 and on putting it all back together I have a breather hose that I cant find a home for.
So far I've connected 2 large breathers to the airbox and 1 vacum hose. I've also connected the fuel line and return plus the overflow and one small diameter breather to the tank.
I'm left with a spare breather hose which is tee'd inline with the small tank breather which I cannot fond a homew for.
Any suggestions????
ahthud is offline
post #2 of 19 Old 02-09-2011, 4:26 PM
Reputation Power: 26
Re: 954 breather pipes HELP
I have the same problem.
Weird, ain't it?
2002 CBR954RR, 1998 VFR800
Deadsmiley is offline
post #3 of 19 Old 02-09-2011, 4:36 PM Thread Starter
Weird, ain't it?
Does your's run ok with it disconnected?
ahthud is offline
post #4 of 19 Old 02-09-2011, 4:43 PM
It runs like a raped ape. I would like to know where this thing goes!
post #5 of 19 Old 02-09-2011, 5:31 PM
Reputation Power: 12
Do you have the cali version? maybe its the hose going to the charcoal canister from the tank
ZeroKool929 is offline
post #6 of 19 Old 02-09-2011, 5:33 PM Thread Starter
No its a UK model so no smog bottle!
The internal diameter is really small as well (smaller than the small breather connected to the tank)
ahthud is offline
post #7 of 19 Old 02-09-2011, 5:37 PM Thread Starter
So is "running like a raped ape" a good thing or bad Sorry us yolkels in the uk dont always get US speak
ahthud is offline
post #8 of 19 Old 02-09-2011, 5:48 PM
It's very good!
Sorry for the confusion.
post #9 of 19 Old 02-09-2011, 5:48 PM
Is it the map sensor vac line? Map bolts to bottom of airbox with one phillips screw on the bottom left sitting on bike.
kristribble is offline
post #10 of 19 Old 02-09-2011, 5:49 PM
I don't have a Cali version.
post #11 of 19 Old 02-09-2011, 5:59 PM Thread Starter
Nope, that ones connected.
ahthud is offline
post #12 of 19 Old 02-09-2011, 6:02 PM
The one I have connects to the bottom of the tank, then about 1/3 of the way down it tees off and then continues on to the fairing slot just in front of the rear tire.
I have no idea where the teed off hose connects too.
I think ahthud has the same situation, correct?
post #13 of 19 Old 02-09-2011, 6:10 PM
Quoted: 9 Post(s)
Reputation Power: 56
Hi
Any suggestions????
This small hose you are referring to does not connect to anything. It just lays on top of the motor. It will drive you nuts until you realize its normal.
SOLD: 03 CBR954
backdoc is offline
post #14 of 19 Old 02-09-2011, 7:22 PM
It's still weird. Why would you tee off a hose that goes to nowhere?
post #15 of 19 Old 02-09-2011, 7:54 PM
Reputation Power: 31
He's just screwing with you, it goes somewhere. He just hasn't found out where.
Or maybe I'm just screwing with you because I know where it goes
ERION929 is offline
Problem breather locksmithuk General Discussion 1 04-20-2009 7:29 PM
i need a carb breather filter for an RRX! johnx144 Honda FireBlade 2 04-20-2009 6:26 PM
breather reroute maybe919 Honda Naked Sportbikes 1 04-03-2009 5:17 PM
99 RRX Tank Breather pipes chewy Honda FireBlade 5 04-21-2007 9:52 AM
Crankcase breather mmmickey Honda CBR 600 3 11-07-2004 2:24 AM
