929 pistons/954 head gasket - Honda Motorcycles - FireBlades.org
post #1 of 16 Old 02-10-2011, 11:03 PM Thread Starter
Reputation Power: 31
1) Just out of curiosity, on a stock bore 929, are there higher compression pistons available without changing bore. And if so, what is the prep for the cylinder walls as well as what type of characteristics would come along with this.
2) I understand you can install a 954 head gasket on the 929 and if so, has anyone done this and if so what notice did you see in performance. Also if the calculations were made, what did it bring the compression ratio up to?
thanks, Bob
ERION929 is offline
post #2 of 16 Old 02-11-2011, 1:14 AM
Re: 929 pistons/954 head gasket
thanks, Bob
Of course. Wiseco list a 13.2:1 piston and I'm sure others do them as well. A light hone is all you need. Expect more heat than power.
Yes, the heads and gaskets are the same pattern. I would expect _lower_ compression, not higher. The bigger bore size of the gasket would add volume. Are the 929 and 954 gaskets different thicknesses?
post #3 of 16 Old 02-11-2011, 1:38 PM Thread Starter
I was told the 954's are thinner thus increasing compression. Never bought the two and measured though.
Thanks
ERION929 is offline
post #4 of 16 Old 02-11-2011, 2:12 PM
Thanks
I haven't measured the thickness of the gaskets either.
The tiny increase in compression the 954 (11.5:1) has over the 929 (11.3:1) is probably just down to the 1mm bigger bore. A larger bore area under the same combustion chamber has a larger squish area (basically where the piston is almost touching the combustion chamber - no combustion occurs in this area) around the outer edge which increases compression. I've just pushed one of my engines out from 73mm bore to 90mm bore which makes a huge squish area around the combustion chamber so I need to do a lot of chamber work on it.
post #5 of 16 Old 02-11-2011, 2:24 PM
Reputation Power: 59
I would change out the headgasket for a thinner one.. but I wouldnt go for higher compression pistons.
With that being said, take the head off and take it in to get port and polish. Then degree the cams or get race spec cams.
Friends race bike.. that alone got him 10hp.
Krazed is offline
post #6 of 16 Old 02-11-2011, 2:27 PM
I agree, unless the engine is coming apart anyway the expense of replacing the pistons doesn't make it very good bang for buck.
Which part of the port/polish and cams got him the 10hp on its own?
post #7 of 16 Old 02-11-2011, 5:04 PM
Reputation Power: 17
I would think the 929 and 954 gaskets would be the same thickness just different bore
I measured my 954 gasket and it is .024-.026"
Can anyone measure a used 929 gasket?
smiff95 is offline
post #8 of 16 Old 02-11-2011, 5:07 PM
How much thinner would you go?
smiff95 is offline
post #9 of 16 Old 02-11-2011, 6:18 PM
It went from 108hp with full exhaust and PCV to 118hp. so I guess you can say it added to it, but really 10 hp from that is nice.
It was an R6 I will admit, but still I cant imagine the 929 being a hell of a lot different in gains.
Krazed is offline
post #10 of 16 Old 02-12-2011, 9:16 AM
So port/polish _and_ cams got 10% improvement?
post #11 of 16 Old 02-12-2011, 9:20 AM
You need to measure your piston-to-valve clearance and work from that.
I took 0.55mm out of my '98 GSXR750 by splitting the head gasket and removing the base gasket with no problems at all.
I took 1mm out of my Suzuki Swift car engines with no problems as well.
post #12 of 16 Old 02-13-2011, 2:36 PM Thread Starter
Suzuki Swift?
ERION929 is offline
post #13 of 16 Old 02-13-2011, 8:19 PM Thread Starter
To lazy to get out the manual, but briefly what is involved.
Thanks
ERION929 is offline
post #14 of 16 Old 02-13-2011, 10:28 PM
Suzuki Swift?
Suzuki Swift - Wikipedia, the free encyclopedia
post #15 of 16 Old 02-13-2011, 10:29 PM
Thanks
To replace the pistons?
A _complete_ engine teardown.
Oil from head gasket QQQ Honda FireBlade 11 04-25-2010 6:21 AM
head gasket badpie426 General Discussion 10 03-27-2010 11:30 PM
Need a Head Gasket Cajun Honda CBR400RR 5 01-12-2009 12:27 PM
CBR954 High Compression Pistons & head work King Kenny Honda FireBlade 3 01-12-2008 5:32 AM
Head gasket help vernieman21 Honda CBR 600 17 07-12-2007 5:07 PM
