2000 929 wont start - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 02-18-2011, 6:52 PM Thread Starter
2000 929 wont start
I had to replace the tank due to the fact it starting leaking, but after replacing the tank the bike will not start. The starter comes on but the bike will not kick over. I already replcaed the plugs, checked the fuses and put in new fuel after draining the old. Im about to deploy and really dont wanna leave with it not starting and it sitting for a year. So any help would be greatly appreciated
natorious is offline
post #2 of 7 Old 02-18-2011, 7:39 PM
Re: 2000 929 wont start
Take tank off, spray starting fluid into the intake track and try to start it.
unfetteredmight is offline
post #3 of 7 Old 02-18-2011, 8:21 PM
Is the pump priming when you turn the ignition on?
Do you have spark?
How long since it ran last?
post #4 of 7 Old 02-19-2011, 11:30 AM Thread Starter
yes the pump is priming and it started a month ago for a few seconds and then died
post #5 of 7 Old 02-19-2011, 11:34 AM
But before that it was running just fine?
post #6 of 7 Old 02-19-2011, 11:56 AM
Ok so let's find out which way to go, ignition system or fuel system.
You can buy a new plug, attach it to each plug wire. Ground it to the block, start it and see if you have spark, doing this for each one or
You can just spray starting fluid into it and see if it runs.
Runs, its a fuel issue. Doesn't run, it's a spark issue. Simple and then we'll know which system to focus on.
post #7 of 7 Old 02-19-2011, 12:47 PM Thread Starter
yea it was running fine before and ill try that out
2000 929 wont start Haydenracing Honda FireBlade 5 07-10-2010 10:00 PM
1999 Fireblade hard start, now wont start.... MFB_87 Honda FireBlade 15 03-18-2010 11:58 PM
2000 CBR 929RR wont start now. JohnBoy21 Honda FireBlade 8 03-08-2010 8:52 PM
2000 CBR929 Wont start kwaltzer Honda FireBlade 30 12-14-2009 12:06 PM
2000 cbr 929rr cranks but wont start help!!! honda#2 General Discussion 8 09-10-2009 11:35 AM
