Oil Light on - Honda Motorcycles - FireBlades.org
post #1 of 13 Old 04-21-2011, 8:02 PM Thread Starter
Oil Light on
Hello members,
Im new here but recently i changed my oil and plugs and when starting the bike, the Oil Light next to the neutral light blinks spurratically. Any ideas why this would be? i changed with 10w-40 synthetic HP4 and a honda filter. shouldnt have had any problems. Thanks for the help
DiabLO is offline
post #2 of 13 Old 04-21-2011, 8:29 PM
Reputation Power: 15
Re: Oil Light on
Originally Posted by DiabLO View Post
Hello members,
first off....where in NY are you? anywhere near buffalo? Second...did you let it run for a couple minutes and then check the oil level again to make sure it is at the proper level? if its at the proper level i would take a guess that it might be a sensor in the oil pan that might be going..what year bike is it? How much oil did you put in? is the filler cp back on along with the dip stick(if it has one)...because those keep the system pressurized and with a loss of pressure it might cause a light to be thrown...not sure?
#1 CBR is offline
post #3 of 13 Old 04-21-2011, 8:30 PM
Re: Oil Light on
oh and BTW....
if your near buffalo we should go for a cruise sometime!
#1 CBR is offline
post #4 of 13 Old 04-21-2011, 8:33 PM Thread Starter
Re: Oil Light on
Thanks! Im actually in New Paltz. Its a 2003 CBR 954RR i'll check the oil cap but it should all be fine. just made me worry because it blinks when starting up. and just stays on while riding. I put in 3.7L of HP4 oil. shouldnt have caused a problem. Thanks for the response and welcome.
DiabLO is offline
post #5 of 13 Old 04-21-2011, 9:12 PM
Location: Mostly Barbados,sometimes Florida & Western Canada
Re: Oil Light on
If all other items check out such as good oil filter, correct oil and level and the filler cap is in place etc, its possible the oil pressure switch is faulty.
If you replace it and the light still stays on, the next item to check would be the pickup screen and oil pump unit in the engine sump.
I would NOT ride or run the engine until the problem is solved.
900RR is offline
post #6 of 13 Old 04-22-2011, 1:19 AM
Re: Oil Light on
There is no sensor in the oil pan. The pressure switch is in the main oil gallery behind the cylinders.
The filler cap has no effect on oil pressure.
post #7 of 13 Old 04-22-2011, 1:24 AM
Re: Oil Light on
Hello members,
I would probably replace the filter. If it makes no difference then you have a spare filter for your next oil change.
Then I would unscrew the oil pressure switch and see if oil is coming out of the gallery. It will be messy unless you rig up a clear hose with a threaded fitting on it, or just buy a cheap auto oil pressure gauge as they generally come with clear oil line and the fittings - as well as telling you exactly how much pressure you have.
post #8 of 13 Old 04-22-2011, 4:45 AM
Reputation Power: 59
Re: Oil Light on
Is 3.7L of oil even enough when you change out the filter?
James Taylor
Krazed is offline
post #9 of 13 Old 04-22-2011, 5:56 AM
Re: Oil Light on
Yep, that's what the manual specifies.
4.0 litres for a fresh engine build.
post #10 of 13 Old 04-22-2011, 6:46 PM Thread Starter
Re: Oil Light on
thanks for the heads up. i'll check the bike tomorrow and repost..
DiabLO is offline
post #11 of 13 Old 04-23-2011, 1:32 AM
Re: Oil Light on
Before you do that, are you sure it's the oil light and not the MIL?
Having been under the tank there's an excellent chance you let something disconnected.
post #12 of 13 Old 04-23-2011, 4:45 PM Thread Starter
Re: Oil Light on
very true sir.. i have the same feeling i am taking the tank and airbox back up and seeing if i left something unplugged. its the red light next to neutral. i was assuming that was the oil light but i may be mistaken. its pouring rain in NY right now so its garage time.. i'll post tomorrow after taking a look. thanks guys
DiabLO is offline
post #13 of 13 Old 04-23-2011, 5:14 PM
Re: Oil Light on
...it blinks when starting up. and just stays on while riding.
Yep, that's the MIL.
Probably the MAP or IAT sensor.
FI light and red light on, PC3 problem? help ezracer Honda FireBlade 18 02-09-2014 4:35 PM
Am I to light for a 600? eatdust General Discussion 13 07-07-2010 8:28 PM
F/S Yoyodyne Carbon Fiber Light Tube w/h light RC51Nash For Sale 1 10-22-2009 10:31 PM
Shift Light / License plate light Gookie Honda Naked Sportbikes 4 02-04-2009 12:27 AM
help my 05 1000rr pgm-fi light & idicator light flashes 3slow 4 fast? impervious Honda FireBlade 9 02-05-2007 1:01 PM
