HONDA 954 GRINDING NOISE - Honda Motorcycles - FireBlades.org
post #1 of 13 Old 05-01-2011, 1:04 PM Thread Starter
Reputation Power: 12
Just noticed a grinding noise today from the bike when I had my kid out for spin, could only here it at slow speed r when I was slowing down , I put the bike up on stands and checked chain and sprockets seems ok when I put the bike in gear while on stands and reved it threw the gears letting the wheel spin and the drop off the accelartor ,there was no grinding noise so it only seems to have the noise when there is weight on the bike could it be a wheel bearing?
blade300 is offline
post #2 of 13 Old 05-01-2011, 2:39 PM
Re: HONDA 954 GRINDING NOISE
It wasn't making this noise before?
Is it only while you're braking on the front?
post #3 of 13 Old 05-01-2011, 5:38 PM Thread Starter
if im driving along in first or second even when i let the throttle off and let the revs come down i can here grinding seems to be coming from the centre or rear of bike, as said befrore when i had the bike up on paddock stands and started , i tried the bike threw all gears and didnt hear any grinding its only when i drive the bike with pillion on the back i can hear grinding
blade300 is offline
post #4 of 13 Old 05-01-2011, 9:09 PM
Reputation Power: 78
Do you still have the HTEV in your exhaust?
BurtonF166 is offline
post #5 of 13 Old 05-01-2011, 9:38 PM
I would try loosening the chain adjusters a half turn and see if that helps.
post #6 of 13 Old 05-02-2011, 5:08 AM Thread Starter
tried that didnt work unfortunatly, and only seems to grind with a passenger on rear, had a look and cant see anything rubbing either
blade300 is offline
post #7 of 13 Old 05-02-2011, 5:09 AM Thread Starter
as far as i know it still in the exhaust
blade300 is offline
post #8 of 13 Old 03-26-2012, 11:32 AM
I'm having a similar problem with my 900RR (except it happens when there's weight on the bike or not and when the engine is both running and off) and its sounding like a metal on metal grinding from the front wheel. Just replaced the wheel bearings and brake pads on both wheels hoping it would fix the issue. But alas, the grinding still remains. Any ideas?
zer0seeker is offline
post #9 of 13 Old 11-02-2015, 10:22 PM
Any answer to this it's happening to me now I'm afraid it's my output shaft bearing
dmcdevitt23 is offline
post #10 of 13 Old 11-03-2015, 8:57 PM
Reputation Power: 8
Make sure the right spacer is on the right side. If your caliper is rubbing the rotor the spacers are swapped.
Beyond fear is freedom.
SA954RRWA542 is offline
post #11 of 13 Old 11-03-2015, 10:25 PM
Quoted: 29 Post(s)
Have you adjusted/tightened the chain recently? Like mentioned before, back it off little more lube it up and check it again. It gets tighter when there is a load on it.
jdoni is offline
post #12 of 13 Old 11-08-2015, 7:43 PM
Reputation Power: 8
Any progress?
post #13 of 13 Old 11-10-2015, 2:14 AM
Reputation Power: 6
I had the same grinding noise and feeling a while back.it was alright when it was only me on the bike but when my fiancÚ was on the back the whole back vibrated then it was the worst!
Here is a link to my thread about how to fix it and what was wrong . . don't know if I am allowed to post link so just tell me and I will take it off.
https://www.fireblades.org/forums/hon...ll-sudden.html
The one who follows the crowd will usually get no further than the crowd.The one who ride's alone is likely to find himself in places no one has ever been
motomodmach is offline
HELP Meee.... drive sprocket grinding noise :( Picante Honda RC51 10 11-22-2009 10:38 PM
Honda CBR1000RR 2007 Noise in the engine, Help!! proracer Honda FireBlade 5 05-19-2009 9:33 PM
EBC HH pads on a 929, more noise than OE Honda? TheJackal Honda FireBlade 20 09-25-2008 9:01 AM
My CBR 929 is making a grinding noise... CBR_929_kid Honda FireBlade 6 06-16-2008 5:22 AM
Front end making grinding noise!!!! Bdonkadonk74 Honda FireBlade 12 09-06-2004 4:06 PM
