929rr no spark, fuel pump is priming - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 05-01-2011, 2:09 PM Thread Starter
Quoted: 21 Post(s)
Reputation Power: 10
hello everyone, I just took my 929rr apart this winter to paint the frame and swingarm and adjust the valves while i had it all apart. Everything went well, got it all back together and running in my friends basement where we were doing the work. So myself and a couple of my friends carried it up out of the basement and put some fresh gas in and now it is not running. The fuel pump is still priming (i do not have a stock ignition on this bike because i lost the key) So i have the ignition wires connected to a hidden switch for a "key". The zener diode that came with the ignition broke at the beginning of last year so i had to take a few days and do some research and find out that you can use a resistor in place of the diode to lower the voltage so the fuel pump would prime. I just replaced the resistor to be safe. So here i am now, The bike is cranking, the fuel pump is priming but there is no spark. Now i am not 100% sure if the injectors are putting fuel into the cylinders but i am pretty sure cuz when i crank it for a while it definately smells like gas in the tailpipe. I have gone back and made sure all the wiring is connected and it is. My question is, where should i start diagnosing this problem. Please keep in mind that the bike was running before we carried it out of the basement and im pretty sure we didn't disturb and of it when we carried it out. I'm sure it is something dumb keeping it from running but any idea as to what could be causing this would be appreciated. I have a multimeter(although i am no expert at using it) so if i need to run tests on sensors and wiring i can. Keep in mind i am a complete newb at wiring so try to keep it in laymens terms if at all possible. Thanks in advance.
msf0002 is offline
post #2 of 7 Old 05-04-2011, 1:35 PM Thread Starter
Quoted: 21 Post(s)
Re: 929rr no spark, fuel pump is priming
no1 has any ideas?
msf0002 is offline
post #3 of 7 Old 05-04-2011, 4:12 PM
Have a read through my thread (you posted in it). All the tests that unfetterdmight posted are correct. I don't think it's in there, but you can test the cam pulse generator in the same way as the ignition pulse generator. Other than that pretty sure everythings there.
If you want to check fuel, you can pull off the airbox and shine a light down the throttle bodies and you'll be able to see in injectors spray when you crank it.
Random question though, is there any chance you may have cranked it over with the ignition coils disconnected (either at the spark plug or the wires)?
I was recently informed that there are some electronic ignition modules that if the plug boot is not grounded somehow, all the charge that builds up when they try to fire builds up and ends up going back into the Icm for lack of anywhere else to go, and cooks the Icm. I don't know wether or not this is true for this bike or not though, just something to avoid I guess.
If you need help with anything else just let me know
srobinson is offline
post #4 of 7 Old 05-11-2011, 4:59 AM
when my tip over sensor went bad it cut my ignition
turbobluemiata is offline
post #5 of 7 Old 05-14-2011, 4:52 PM
I'm having the same problems.
My 2000 CBR 929RR cut out when i was riding it and wont start again. Changed the spark plugs, checked for blockages in fuel lines and nothing, all seams fine.
Got it to a garage and now he cant find anything wrong with it after spending 10 hours and 300 on new parts, cam pulse generator and the ignition pulse generator.
Comrie is offline
post #6 of 7 Old 05-27-2011, 1:59 AM Thread Starter
Quoted: 21 Post(s)
Is there a way i can bypass a bunch of stuff that could be causing it all at once to get it running? I know there is something with the kickstand and the kill switch. Can the tip over switch(i think its called the bank angle sensor) be bypassed? To bypass these do you have to install a jumper wire in the harness or what? Srobinson,I'm gonna have another look at your post and see if i can wrap my head around it
msf0002 is offline
post #7 of 7 Old 05-28-2011, 10:31 AM
Couple of tests
Side stand - bridge the two wires
Clutch - bridge the two wires
Bank angle - bridge the outside two wires (red/white and green I think it is)
Neutral - ground the wire
I think that's all the safteys, these are to set as a run condition
You can also test using a multimeter set to ac scale
Ignition pulse generator - unplug and probe both wires should read >0.7v while cranking
Cam pulse generator - unplug and probe both wires should read >0.7v while cranking
Fuel pump not priming Kvidalin Honda RC51 10 05-20-2010 12:47 PM
1000rr fuel pump not priming???? pwozzy Honda FireBlade 4 04-12-2010 7:37 PM
Changed mirrors and fuel pump now not priming. ozerionblade Honda FireBlade 1 06-30-2008 10:43 PM
Fuel pump not priming ozerionblade Honda FireBlade 8 03-20-2008 9:22 PM
Fuel pump not priming - cause? cbr_df Honda FireBlade 60 01-10-2007 3:43 AM
