HELP!! - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 05-17-2011, 1:19 PM Thread Starter
HELP!!
I recently laid my '01 Erion down and along with the stator cover being broken, the crankcase has a piece broken where the cover bolts to the case. My question is, if I fix this by welding, will this warp the case any, or should I just spring for a new crankcase? And if I replace the crankcase, do I need to rebuild/overhaul the entire engine?
vincedredd is offline
post #2 of 5 Old 05-17-2011, 2:58 PM
Re: HELP!!
It is most likely repairable by a good welder. Find one and get his opinion.
Yes, replacing the crankcases is a full rebuild.
New cases are US$2000 though.
OEM Parts Honda CBR929RE (CBR900RE) 2001 CRANKCASE - Cheap Cycle Parts
post #3 of 5 Old 05-19-2011, 4:59 AM
Reputation Power: 12
Re: HELP!!
ouch! how bout this?
zero gravity windscreen. reverse / gp shift/ -1 down front sprocket/ speedo drd corrector. bazzaz z-bomb yosh case/stem nut/ oil fill/hotbodies under tail, rideit blk. long levers , sato street hooks, intergrated smoke tail lite lens, HRC solo cowl,yosh carbon/carbon R-77 pipe.
axlD is offline
post #4 of 5 Old 05-20-2011, 11:53 AM
Reputation Power: 9
Re: HELP!!
This seems to happen a lot with these bikes.
Will the frame sliders I bought for my 954 prevent this from happening?
txrider is offline
post #5 of 5 Old 05-20-2011, 2:46 PM
Re: HELP!!
Nope.
Your best bet is probably a heavy duty racing stator cover like NCR does.
