98 CBR900RR idle problem - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 05-20-2011, 12:54 AM Thread Starter
Reputation Power: 12
Under heavier electrical load (ie when the brake lights are on, or the turn signals are on) she loses RPM and chugs a bit and has stalled once or twice. Just had the carbs cleaned and synced and have a 1 month old battery. It's definitely something electrical. The stealership told me it was my plugs and coils most likely and want to charge me an arm and a leg to replace them. What do y'all think? From my searches I'm thinking I need a new r/r but I'm not an expert... hoping to find some answers! Thanks!!
uhhmoney is offline
post #2 of 7 Old 05-20-2011, 1:04 AM
Re: 98 CBR900RR idle problem
Do the tests of the charging system before you order a regulator. It may be something simple like a broken wire or loose connector.
post #3 of 7 Old 05-20-2011, 1:09 AM Thread Starter
I looked for any tutorials/guides but I didn't find much in that way... can you point me in the right direction? I have only had this 900RR for about a month (and this is my first carburated bike) so I'm definitely a n00b... my other bikes have been FI and never had any issues like this.
uhhmoney is offline
post #4 of 7 Old 05-20-2011, 1:12 AM
Tutorial?
It's already detailed in the manual.
If you don't have one download it.
post #5 of 7 Old 05-20-2011, 1:15 AM Thread Starter
Tutorial?
downloaded a pdf of the service manual. thanks a lot, didn't even think of that! will get on this when I get a day off #worktoomuch
uhhmoney is offline
post #6 of 7 Old 05-24-2011, 3:04 PM Thread Starter
Blade, I checked the entire charging system as the manual instructed.
Battery voltage read at around 12.8v with bike off after a 30 minute ride
Resistance between yellow wires from stator 0.2ohm
At the R/R connector:
Green wire to ground - continuity
Red/White to ground - battery voltage (12.8v)
Yellow(s) to Yellow(s) - 0.2ohm
While running:
Battery voltage goes between 13.9v around 2500rpm and drops to 13.4 approaching 5000rpm (shouldn't it rise to around 15v with the increase in rpm?)
All connections look decent and nothing looks burned out.
I left the multimeter connected when I "stressed" the electrical system by pumping the brake to turn the brake light on and off and, as before, the idle speed fell, the battery voltage went down to 12.8v, and the bike audibly chugged and went as low as 1000rpm (and like I said before, would probably stall if I let it).
I disconnected the taillight and did the same brake pumping procedure and she didn't chug once. It is obvious to me that the electrical draw is definitely aggravating the gremlin.
Maybe I'll just leave the system alone and just keep the taillight and brake light disconnected... JUUUUUST KIDDING! But MAN this is kinda frustrating!
***EDIT*** I went to the local auto shop and bought LED replacement bulbs for the rear brake lights and, surprise of the century, NO GREMLIN! They are just as bright as the OEM bulbs but don't draw as much power, so they aren't taxing the system. I don't like leaving things half-assed but this will definitely do until I figure out where the real trouble is...
uhhmoney is offline
post #7 of 7 Old 06-04-2011, 9:09 PM Thread Starter
Solved - The electrical system still didn't feel right, so I kept investigating. I knew that the LED tail lights were just masking the problem, and I *hate* half-ass solutions. The book said to replace the R/R if all tests came back OK and the system was still not acting right so I bought a cheap eBay one to just see... and it alleviated all symptoms. Spark is great, lights no longer dim whether LED or incandescent, engine runs great even at low rpm. I know how reliable eBay rectifiers are... so I bought an oem one from hondapartsnation.
...I dont know why I didn't figure that out sooner! Like I said earlier, this is my first carb bike that I've actually worked on (other than changing the oil or basic stuff like tightening a cam chain etc)... either way, I'm pumped she's finally running well!
uhhmoney is offline
04 f4i idle problem bubbabean Honda CBR 600 1 01-29-2011 12:29 AM
98 honda cbr900rr idle skrew Rocketrider General Discussion 2 01-18-2010 9:35 PM
08 cbr 600 idle problem 227800 General Discussion 4 12-31-2009 7:49 PM
96 F3 Idle Problem onetreecahill Honda CBR 600 5 06-03-2008 3:14 PM
