96 CBR 900rr Carb Calibration question - Honda Motorcycles - FireBlades.org
post #1 of 12 Old 05-21-2011, 4:37 PM Thread Starter
I have a 96 CBR 900RR, and Im attempting to calibrate my carbs. I have devised a Manometer out of 1/4" clear plastic tubing with 2cycle oil as my measuring fluid. My carbs dont have the tit for hooking up the tubing so I took two funnel ends and cut them to fit the top of the carbs. I then ductaped the funnels upside down on the carbs with the tube in the top. This will create a vacuume in the tube. #1 and #2 carbs have been rigged with the steps listed above. I managed to sync #1 and #2. Once I moved my rigging to #3 and #4 the engine will turn over but has great difficulty starting. When it finally fires it will rev. to 3000 and then die. I covered #1 and #2 and hit the starter again and it will idle but idles rough and not for very long. I believe my vacuume for #3 and #4 maybe greater than the Vacuume in #1 and #2. Not sure if #1 and #2 are dead cylanders, but i get plenty of suction from both. I have also replaced the plugs within the last two weeks.
My question is how would I go about checking compression in all cylanders without purchasing a tool? Or do i even need to check my compression?
When I ride I lack power and throttle response. When I dismount i checked the header pipes by spitting on my finger and #1 and #2 are warm but #3 and #4 sizzle my spit.
Also would the muffler being completely hallowed out have an affect on my back pressure causing this malfunction? The guy i bought it from completely hallowed it out no baffle and no packing.
armed is offline
post #2 of 12 Old 05-21-2011, 9:23 PM
Re: 96 CBR 900rr Carb Calibration question
Can you post a picture of what you're trying to do?
I can't fathom what you would need funnels for.
You are merely measuring the vacuum through the intake manifolds and adjusting the throttle plates so each carb has identical air flowing at idle.
post #3 of 12 Old 05-21-2011, 10:34 PM Thread Starter
im going to take pictures, be back in ten.
armed is offline
post #4 of 12 Old 05-21-2011, 10:44 PM Thread Starter
I dont have an http:// link for my pictures and im not very computer savy.. so how should I go about showing you this picture? AH HA... go to member galleries and type in Homemade manometer. you should be able to pull it up.
armed is offline
post #5 of 12 Old 05-22-2011, 3:55 AM
I still don't understand what the funnels are for though. Where are you connecting them to the carbs?
If you haven't got the screw-in adaptors just make them. Get some screws that fit in the holes, drill down their length and cut the heads off. Or use some 6mm aluminium tube and tap a thread on one end.
post #6 of 12 Old 05-23-2011, 2:26 AM Thread Starter
UMMMM, why didnt I think of that?? I was goin all high tech and couldve made it easy. but sometimes the easy eludes me. thanks I will give it a shot and let you know what I come up with.
armed is offline
post #7 of 12 Old 05-23-2011, 8:14 AM
Reputation Power: 50
If you can get the damn balance screws out, just bung in some thin plastic tubing that will seal. I use a 'proper' 4 tube vacuum gauge and this is how I hook up. BTW a balancer unit is worth every penny of the not much that they cost. makes the job easy and once done properly, the engine feels sooo smooth.
jdugen is offline
post #8 of 12 Old 05-25-2011, 8:49 PM Thread Starter
I attach the cones to the top of the carb with ductape. I know janky but, figured it would work, as long as it created suction in the tubes. I guess I will have to invest in a guage. thanks for the input guys.
armed is offline
post #9 of 12 Old 05-26-2011, 1:44 AM
You mean in place of the CV lid?
I'd be amazed if that worked at all.
The vacuum circuit that lifts the slides is very different to the vacuum measured passing through the intake manifold.
post #10 of 12 Old 05-26-2011, 9:08 PM
Does anyone know if the carb diaphrams from a 98 carb would work on a 97 or if the whole carb would work
98cbr9rr is offline
post #11 of 12 Old 05-26-2011, 10:11 PM
The diaphrams are the same for all 900RR's from '92-'97 and CBR1000 from '93-'96.
I don't know if '98 are interchangeable but they're not the same part number.
Bore spacing is the same from '92-'99 so any of those year carbs should fit just fine as a complete bank.
post #12 of 12 Old 05-26-2011, 10:13 PM
thanks, they should call you the BladeWizard bro
98cbr9rr is offline
Tags
calibration , carburetor , carburetor calibration , sycronize
900rr Carb floats 3dpragmatik Honda FireBlade 20 12-21-2010 7:31 PM
95 CBR 900RR--WHERE CAN I GET A CARB REBUILD KIT? Busted9R Honda FireBlade 1 12-29-2009 3:51 PM
900rr carb sync problem kiai Honda FireBlade 12 05-31-2008 12:42 PM
HELP! '98 900RR carb vacuum spring 66droptop Honda FireBlade 6 07-24-2006 3:40 PM
carb removal 900rr JohnnyInsano Honda FireBlade 1 02-05-2006 8:45 PM
