929 Brake specifications. - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 05-24-2011, 11:34 PM Thread Starter
Hi guys, I'm trying to fill out a form for vehicle registration/licensing reasons here in New Zealand...
They are asking for the manufacturers acceptable limits on thickness of the pads and rotors... Does anyone have this information?
Thanks.
Nana is offline
post #2 of 4 Old 05-25-2011, 12:54 AM
Re: 929 Brake specifications.
Thanks.
The front discs will have "Min. Th. 3.5mm" stamped on them if they're OEM. The rear is thicker from memory. These specs though are likely to be different depending on the disc manufacturer.
I'm not aware of a specified minimum thickness for the pads as the pads have their own wear indicator grooves in them. Do you need to provide proof of the manufacturer's spec? If not, just put 1mm as I doubt many pad manufacturer's wear indicators would go below that.
post #3 of 4 Old 05-31-2011, 4:13 AM Thread Starter
Yeah the rotors are OEM and have the specs stamped so that's all good. Its the pads I'm not too sure about... I thought it might say something in the Honda manual about the limits of stock brakes?
Nana is offline
post #4 of 4 Old 05-31-2011, 4:57 AM
It does. Just like every other manual it says to replace them when they reach the wear indicators.
CBR400RR Specifications LoopyLee Honda CBR400RR 39 06-28-2015 11:10 AM
2008 DN-01 - Photos and Specifications LoopyLee Honda Tourers 17 07-11-2009 8:04 PM
Front brake lever won't turn on brake light kevinb6825 Honda FireBlade 3 04-13-2008 8:40 AM
1988 F1 Hurricane has stiff brake lever & 1 brake rotor getting hotter than the other bcolins Honda CBR 600 5 08-04-2007 3:48 PM
Brembo BRAKE MC & Galfer Superbike BRAKE Lines southpark460 Honda RC51 0 01-08-2006 1:28 AM
