2002 954 3rd gear noise? I NEED HELP - Honda Motorcycles - FireBlades.org
post #1 of 14 Old 05-27-2011, 10:07 PM Thread Starter
I recently started hearing a slight to louder noise/rattle on my 02 954rr in 3rd gear. While in 3rd gear only when the throttle is cracked or closed, but not while throttle is open, OR WILL GO AWAY AS THROTTLE IS APPLIED. I messed my ankle up at work and have had a couple false shifts but not into third. I had heard a little noise, not noticeable. Had the back tire put on and it got much louder. You can pull on the chain and it will move a little under 1/2 inch or less. The indicator on my back wheel adjustment is on the 4th notch, from the back line. stock sprocket and chain, with a 190/50 tire. Is it the gear dogs, shift fork. i NEED HELP
Krisdog is offline
post #2 of 14 Old 05-28-2011, 2:08 AM
Re: 2002 954 3rd gear noise? I NEED HELP
What do you mean by the half-inch of chain movement? Do you mean the chain is far too tight?
post #3 of 14 Old 05-28-2011, 2:19 AM Thread Starter
Well if I pull on the chain with my hand from the top it will move about an inch of slack, if I play with the slack on the bottom of the chain it wont move down but has twice as much play if I lift upwards............ not sure correct amount or tightness, whats to loose or tight?
Krisdog is offline
post #4 of 14 Old 05-28-2011, 2:21 AM
Then loosen off the adjusters.
post #5 of 14 Old 05-28-2011, 2:32 AM Thread Starter
so it sounds too tight to you, thx by the way
Krisdog is offline
post #6 of 14 Old 05-28-2011, 2:41 AM
If you are correctly describing the chain tension, then yes, definately too tight.
post #7 of 14 Old 05-28-2011, 2:46 AM Thread Starter
first thing in the morning. Whats a good guide line to the correct tension?
Krisdog is offline
post #8 of 14 Old 05-28-2011, 2:49 AM
You don't have a workshop manual for your bike?
40-50mm of slack - measured as described in the manual.
post #9 of 14 Old 05-28-2011, 2:57 AM Thread Starter
I need manual. I guess I sound ignorant but you helped me on my newbie Q. I thank u
Krisdog is offline
post #10 of 14 Old 05-28-2011, 10:29 AM
If you search Google or Torrents the manuals are available until you can buy a hard copy.
post #11 of 14 Old 05-28-2011, 1:33 PM Thread Starter
Here is a video of what my chain looks like with tention buy hand. A link to a youtube video I uploaded of my bike on stands 1st--> 3rd after I tried to adjust the tention. It's flopping around and making noise!!! BUT I DIDN'T HEAR THE CLANKING NOISE I heard while riding (unless that was it) in 3rd while on stands.
Krisdog is offline
post #12 of 14 Old 05-28-2011, 4:17 PM
YouTube - ‪02 954 noise issues‬‏
That's a lot more than half an inch of play and looks just fine to me.
The jumping around is also normal when the chain is unloaded.
post #13 of 14 Old 05-28-2011, 4:30 PM Thread Starter
I said screew it and took it to a local shop. It's definitely internal. There saying got to pull motor to get to trans. its my 3rd going. I dont know if its the fork cause or what. its not popping out but its a dog problem or so on........ thx for your replies your appreciated!!!!! cbr 954money pit. lol
Krisdog is offline
post #14 of 14 Old 05-29-2011, 9:39 PM
Ouch that sux . Hope it all works out for you.
BTW - that's a great looking bike.
Bob H. is offline
Gear noise on the 1000RR Max Honda FireBlade 5 03-18-2014 7:37 PM
Please Help With Ringing/Whistling Noise 2002 CBR 954 bhoffco General Discussion 11 09-17-2013 5:36 AM
CBR929RR Engine Noise & Gear Slip SHiBBY Honda FireBlade 7 01-07-2011 2:49 PM
Whinning noise in 1st gear on 900rr 95erion Honda FireBlade 12 04-12-2010 5:34 PM
NOISE IN 2ND GEAR lucho Honda FireBlade 3 02-02-2006 11:03 AM
