2006 Fireblade Hydraulic Clutch - Honda Motorcycles - FireBlades.org
post #1 of 3 Old 05-28-2011, 3:58 PM Thread Starter
I have a 2006 Fireblade which was working fine until I put it away for winter 9 months ago (had work done in the house which got in the way)!!
Now I have no clutch at all.
If I pull the lever I have nothing, even when pumping a few times. The master cylinder is full (in fact it is over the max level if that makes a difference).
The clutch is fully engaged as if I put it in gear with the engine off (on a paddock stand) then turn the engine on it turns fine.
Is there anything simple I can do to get it free before I borrow a van to get it to the dealer.
Please be gentle with me as I am not very technical with this, hence I got the bulletproof Honda as my last 4 bikes.
Thanks
rupertclark is offline
post #2 of 3 Old 05-28-2011, 4:32 PM
Re: 2006 Fireblade Hydraulic Clutch
Thanks
You need to drop it into first gear with the engine off, pull the clutch lever and rock the bike backwards and forwards to free up the clutch. It helps to warm the engine up to operating temp first as well.
post #3 of 3 Old 05-29-2011, 6:57 AM Thread Starter
Many thanks bladeracer, that seemed to do the trick just perfectly.
I forgot how quick the bike is, need to get back into it properly now!
Times were so much harder before forums, makes me wonder what I used to do!!
Thanks again
Advantages/disadvantages of a hydraulic clutch? djice929 Honda FireBlade 31 07-16-2013 3:13 AM
07 600rr - Hydraulic Clutch GuyPavelo Honda CBR 600 4 06-06-2009 2:01 PM
Hydraulic Clutch for 929 zfrilly2 Honda FireBlade 6 06-04-2007 2:41 AM
Hydraulic Clutch ?? TGZ13 General Discussion 9 10-12-2004 5:50 PM
Hydraulic clutch on CBR1k? Skully Honda FireBlade 5 04-18-2004 7:34 PM
