929 starts only w/ Power Commander removed. Advice? - Honda Motorcycles - FireBlades.org
post #1 of 3 Old 05-31-2011, 2:03 PM Thread Starter
Reputation Power: 17
Hey all.
I've had a Power Commander (non-USB) on this bike for 4 or 5 years now. Never had a problem with it. Bike always started fine. Last year I had the bike run on a dyno and had the map adjusted a bit. Continued to start fine and run great for the rest of the year.
After a winter in the garage, I couldn't get the bike started. It turns over, the starter cranks, etc. Not a battery problem. I replaced the spark plugs. Same problem. Finally (I should have done this first!), I unplugged the Power Commander. The bike started up right after that.
Plugged the Power Commander back in. No start. Unplugged it again: started fine.
Has anybody else ever seen this? Could something have happened to the PC over the winter? Maybe with the freezing weather it lost the map or the programming? Or do these things just die over time?
Is there a way to fix it? Or can I at least recover the map to put onto a new PC if I have to buy a new one?
Any thoughts or advice would be appreciated.
I did a track day with the stock fuel mapping yesterday, and I remembered why I enjoyed the PC so much. I'm going to plug it in again and see if it starts. Maybe after a day running some clean new gas through the bike at the track day, it will start again with the PC....
--- D
Duster929 is offline
post #2 of 3 Old 05-31-2011, 2:13 PM
Re: 929 starts only w/ Power Commander removed. Advice?
Originally Posted by Duster929 View Post
Hey all.
--- D
PC's are known to fail. I believe Dynojet will check it out for a fee.
If you can still read it via computer then you can certainly download the map.
post #3 of 3 Old 06-08-2011, 8:27 PM
had the exact same problem on my 929, after everything was said and done, i ended up having to put a new pc on it. old one just took a crap i guess.
kwaltzer is offline
CBR 929RR-954RR Power Commander PCIII USB, Power Commander Ignition module, Hub, , Cl like2ryde For Sale 32 05-04-2012 1:17 AM
Loss of power strange sputtering, starts fine and tears sgtmajrepman Honda FireBlade 1 10-11-2009 3:34 AM
Seeking Power Commander III USB Map advice... oldfart Honda FireBlade 14 05-03-2009 9:42 PM
starts but no power zachyfarms Honda SuperHawk 7 05-19-2008 6:01 PM
Changed plugs, bike starts but stops immediatel..... need advice from the gurus plz chuck.cbr99 Honda CBR 600 8 10-04-2007 5:35 PM
