charging when cold but not when engine warms up. - Honda Motorcycles - FireBlades.org
post #1 of 2 Old 06-01-2011, 11:02 PM Thread Starter
Reputation Power: 10
I recently replaced the stator on my 1986 Honda VT-700-C, it worked just perfect but then slowly quit charging the new battery. so my question is......, when the origional stator fried before I put in the new one, was it cause of the rectifier/regulator?. the part's house say's they have hardly ever seen a bad alternator rotor.
ylem is offline
post #2 of 2 Old 06-02-2011, 2:49 PM
Reputation Power: 11
Re: charging when cold but not when engine warms up.
It sounds like there could be another problem causing the charging coil to fail. I would check the reg/rec next. coils can work (have continuity) while cold, but as they get hot they can break down, then start working again as it cools. Not that easy to check unless you can find a way of heating the coil whilst checking continuity. You could put it in a pan of oil on a hob.
shittyarsedmonk is offline
Engine noise when starting 954 in cold veeko Honda FireBlade 11 02-03-2009 9:54 AM
To check oil level when engine hot or cold? blue89turbo Honda FireBlade 1 06-19-2008 12:11 AM
You know its cold when... steingar Off-Topic 12 02-07-2007 10:57 AM
Cold track + water + cold tires = ? Red Rider Track Days / Riding Schools 19 05-25-2004 7:01 PM
Help with engine ticking (upper engine (cold)) Darrell262 Honda FireBlade 12 09-26-2003 6:04 PM
