No Fuel exiting tank - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 06-03-2011, 2:57 PM Thread Starter
Hi Newby here,
1999 CBR900RR.
Can anyone thro' some light on why there's no fuel coming from fuel tap in 'Reserve' or 'On' position
I've tried sucking but there seems to be a resistance.
If I blow it makes whale song noises....! Made the missus laugh and the dogs started howling but hey......no wiser!
Diaphram is good inside tap.
It has been standing for a while.
Any ideas greatly appreciated.
Thanks.
RR_MeHearties is offline
post #2 of 5 Old 06-03-2011, 5:11 PM
Re: No Fuel exiting tank
Originally Posted by RR_MeHearties View Post
Hi Newby here,
1999 CBR900RR.
Thanks.
hi mate, dont quote me on this one as i am very new to the blades but i believe there is a kind of filter gauze inside the tap (?) so i would check that first. dismantle it carefully and blow a bit of compressed air through (back up the pipe) as well ...
flatBARblade is offline
post #3 of 5 Old 06-04-2011, 12:00 AM
Hi Newby here,
1999 CBR900RR.
Thanks.
You are sucking on the vacuum line?
post #4 of 5 Old 06-04-2011, 7:26 AM
oh sugar ! yeh keep forgetting the newer models have vac line for fuel ...
mehearties - put the fuel exit pipe from tap into a fuel can etc then give a little suck on the vacuum line and then kink it to hold the vacuum. the fuel should start coming out then. if you ever need to drain the tank you can cable tie the vac line so it is kinked (dont go overboard) and allow fuel to drain.
definately first confirm you have the pipes correct ...
post #5 of 5 Old 06-04-2011, 11:20 AM
Don't they have a PRIME position on the tap?
There's usually a prime position which manually pushes the diaphram valve open so you can fill the float bowls when they've been drained.
900 RR fuel tank mod Dunc Honda FireBlade 33 06-28-2013 12:19 AM
fuel tank natorious Honda FireBlade 0 06-05-2010 9:13 PM
Fuel Tank / Fuel pump seal ugt33 Honda RC51 0 10-24-2008 3:13 AM
WTB Fuel Tank for 919 Loyalo Wanted 1 09-05-2008 1:56 PM
Heavy steering exiting corners Mavic Honda FireBlade 7 05-24-2003 11:07 AM
