900RR fuel pump not running ? - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 06-03-2011, 3:01 PM Thread Starter
Hi guys just a quick one, ive come to start my 95 blade for the first time since i bought it a few weeks ago and it turns over fine but im not hearing the fuel pump running ... what exactly stops the fuel pump from running ? im presuming it starts as soon as ignition is turned on ? im hoping there is a really simple answer which is why i posted here before diving into the loom with the Fluke. thanks in advance
flatBARblade is offline
post #2 of 6 Old 06-04-2011, 12:12 AM
Re: 900RR fuel pump not running ?
The fuel pump will start when you press the starter button.
When the engine is running the pump will continue to run.
Was it running when you bought it?
post #3 of 6 Old 06-04-2011, 6:16 AM Thread Starter
Thank you bladeracer, this is the information i was really looking for ! i wasnt sure WHEN the pump was supposed to run so basically only when the engine itself is spinning ...
no it had been sat for a couple of years and hence battery was knackered, fuel old etc etc. so i offered him bottom price with regards to all this.
I was actually struggling to use the search function using two words (it never finds any results!) but i tried one word last night (much better idea) and found a thread on bypassing the pump. I tried this out and the bike fired up with a little choke so its all good.
thank you again mate !
post #4 of 6 Old 06-04-2011, 4:14 PM Thread Starter
i unplugged the fuel pump and ran the bike with the fuel straight to the carbs. once running i checked at the socket for the pump plug and had 15 odd volts there so looks like fuel pump could be fine. thanks for clearing that up bladeracer
post #5 of 6 Old 06-04-2011, 4:47 PM
where else is the fuel supposed to go besides straight to the carbs, I mean I know to the pump but where is the pump located??? thats what it does on my 97
98cbr9rr is offline
post #6 of 6 Old 06-05-2011, 2:23 AM
He means he bypassed the pump so the fuel is gravity-fed.
The pump is under the tank. You only need the pump when the fuel level in the tank falls below the level of the float valves in the carbs.
Fuel Pump Alternatives for '93 900rr pdxbret Honda FireBlade 19 09-25-2014 6:47 AM
93 900rr from fuel pump to gravity feed? jeffrow37341 Honda FireBlade 1 03-19-2013 2:39 AM
WTB: fuel pump for F3 F4 or 900RR penguinf4 Wanted 2 09-30-2010 9:43 PM
95 900RR Fuel Pump DSKILLZ Honda FireBlade 5 06-26-2008 4:16 AM
94 900RR fuel pump and relay needed xxnightraven73x Wanted 0 12-20-2006 7:30 PM
