cbr900rr misfire under load - Honda Motorcycles - FireBlades.org
post #1 of 2 Old 06-08-2011, 4:02 AM Thread Starter
Hi guys, im new to this site, im having a bit of trouble with my blade, 93 cbr900rr.
Ive spent alot of time searching existing threads and have sorted some issues out but still have a few questions you might be able to help with.
Bike was running mint untill i reved engine to around 7grand, then it started missing and backfiring,so i limped home sounding like a rotary
This is what i know so far
Bike runs fine when engine is cold, after 5mins of riding it starts missing again
Im in the process of changing plugs, so far plugs 2, 3, 4 are covered in fuel, plug 1 covered in oil, will get new plugs tomorrow
Air filter is clean
I noticed that the coils have been purchased from a wrecker and they say in white marker cbr250, would this cause the bike to not cope at high revs and foul the plugs??
Also the rubber rings that go around top of carbs and bottom of airbox, there is a gap around one of them, would this be causing a vacum effect?
Cheers again for your help
rxweaponz is offline
post #2 of 2 Old 06-08-2011, 2:36 PM
Reputation Power: 54
Re: cbr900rr misfire under load
I'm not sure about the coils But I would guess that CBR250 coils wouldn't be right. The collars being loose or off would cause some issues. I would recommend fixing these two issues before you check any other, besides the plugs. So, go ahead get the plugs, and coils. Then tear into it. Replace the plugs and coils, then make sure your airbox is seated correctly. Lastly put it all back together and go for a ride. See how it's running, and make sure to check the plugs when you get back. This will let you know exactly what the remaining issues are.
Rendell is offline
misfire under load jberdcbr900 Honda FireBlade 11 11-01-2009 3:42 PM
No load Misfire on 93 cbr900rr windman Honda FireBlade 9 09-12-2009 12:44 PM
misfire help!!! Sweet954RR Honda FireBlade 14 07-05-2008 10:43 PM
Misfire? Johnny Honda FireBlade 10 03-28-2004 10:52 AM
