steering damper n bracket mounting for 954; 954 speed - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 06-09-2011, 9:42 AM Thread Starter
Does anyone has second hand steering damper and mounting bracket for 954 for sake. Can reach me at [email protected]. note i from singapore. Would appreciate if anyone can response.
Second i need advice. Just took hkod of 954 recently and when i reached 180 kph my bike seems to pogo. Does it mean i need to replaced fork and rear suspension spring? can also tell me as i heard from mech that the 954 is light at rear and hv to control speed with out sudden push on throttle or the rear will swing upfront . Is this true as if i ride on long ride most of my friwnds are on zzr and haya and they ride average 220 kph but at times they add numbers to the speed
This ride is on long highway in malaysia where our speed speed genreally hit 250 kph abv where possible.
How or what is max speed of 954 can do... any info?
davide55 is offline
post #2 of 6 Old 06-13-2011, 5:26 AM
Reputation Power: 9
Re: steering damper n bracket mounting for 954; 954 speed
what you describe is a known problem of the 954.
I donīt have a stearing damper, only a answer of your "POGO"
Honda changed after the knowing problem the steering head bearings, but the problem was still there, coz the adjustment of the new bearings is a very difficult job. And the advice was to use a steering damper.
I know the highway, coz 4 years KL, and I remember some good fights on the old Shah Alam race track with the malaysian guys.
Setup:
(Drivers weight 70-85Kg)
(U = turns, see your Manual)
TRACK
FRONT
Preload 1 U
Reload 0,25 U
Compession 7 U
Niveau : standart
Tyre Pressure 32 psi
REAR
Preload 1 U
Reload 0,25 U
Compession Step 6
Niveau: deepest
Tire pressure 36 psi
OMEGA is offline
post #3 of 6 Old 06-13-2011, 5:49 AM Thread Starter
Thanks for advice... i guess you rode the 954....Hi Omega.. i heard about pogoing. Not many mechs in spore familiar with the 954. I wonder if i made a big mistake to buy this blade....
The shop that sold me this bike ... i kind piss off... ok its 9 year old bike... one bike key only n no mAnualso thanks at least i hv your input on the fork and rear suspension. Thats about my weight. i.e.70 kilo. You mentioned head bearings.. here i am ignorant ... wh part is it? Wheel bearings or steering .cone bearings. Will a damper solve.this and prevent a nasty accident. Someone told me to put ohkins springs in front and rear suspension.....get it tune n set... is this bike too light on the rear that it might swing up in sudden trottle
davide55 is offline
post #4 of 6 Old 06-13-2011, 5:54 AM Thread Starter
. Oi was told its a good bike... but los of buts...Thanks for advice... i guess you rode the 954....Hi Omega.. i heard about pogoing. Not many mechs in spore familiar with the 954. I wonder if i made a big mistake to buy this blade....
The shop that sold me this bike ... i kind piss off... ok its 9 year old bike... one bike key only n no mAnualso thanks at least i hv your input on the fork and rear suspension. Thats about my weight. i.e.70 kilo. You mentioned head bearings.. here i am ignorant ... wh part is it? Wheel bearings or steering .cone bearings. Will a damper solve.this and prevent a nasty accident. Someone told me to put ohLins springs in front and rear suspension.....get it tune n set... is this bike too light on the reAr that it might swing up in sudden throttle
davide55 is offline
post #5 of 6 Old 06-13-2011, 6:32 AM
Reputation Power: 9
1. if your 954 is in good condition, you haven`t made a mistake to buy, so be happy
2. there was a free Honda recall to change the bearings, if you donīt know if its done, call Honda, give them the frame number.
3. fit a stearing damber, oehlins or other known brand (LSL, HyperPro) will be ok
4. if you want to drive the 954 for long years, you can think about, to buy "second hand" oehlins suspensions, otherwise keep your money
5. the track setup will be ok for your weight
bearings, how to change (in german, but with pics)
Lenkkopflager wechseln - Lexikon - MOTORRAD online
In Germany, after Honda changed the bearings and the test driver fit an damper, the 954 was on the second place in the magazines.
some advices (german) use "google translater"
http://www.motorradonline.de/de/news...-magazin/96856
OMEGA is offline
post #6 of 6 Old 06-13-2011, 6:39 AM
Reputation Power: 9
if the rear swing, the setup is to soft
OMEGA is offline
Scott's Steering Damper & Mounting Kit rvtjonny For Sale 2 02-28-2011 3:53 PM
Scotts steering damper. Mounting kit fits 954 standuprick For Sale 0 02-06-2009 6:16 PM
WTB 954 Piston style damper mounting bracket t4rusaf Wanted 0 10-02-2007 2:46 AM
Mounting Kit for Extremetech Steering Damper TheJackal Honda FireBlade 2 03-25-2007 10:22 AM
WTB: Scotts Damper Mounting Bracket for 954 Ross954RR Wanted 1 05-22-2006 4:36 PM
