Early blade cracked forks - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 07-05-2011, 8:23 AM Thread Starter
Hey all, i recently took my 93 fireblade in to the garage to have the fork seals replaced, when i collected the bike the guy at the garage told me that one of the cast pieces on the end of the fork had a 3 inch crack in it!!Has anyone else ever heard of this?
So my problem now is getting hold of either an end piece or full set of forks for an early blade which so far appears to be like rockin horse s**t!
Does anyone know if i can use forks from a newer model and what would need changing to do this?Or maybe the fork ends off newer forks will fit my forks? I have no idea whats likely to fit? any help much appreciated, thanks in advance
bladerider78 is offline
post #2 of 8 Old 07-16-2011, 9:46 AM Thread Starter
Re: Early blade cracked forks
anybody?????
post #3 of 8 Old 07-16-2011, 12:15 PM
Reputation Power: 59
.. If you have to replace the full setup.. I would find out what Front end you can run and upgrade it.
Something like an RC51 setup.
James Taylor
Krazed is offline
post #4 of 8 Old 07-16-2011, 1:36 PM
Reputation Power: 51
There was a recall on this, free replacement. Dont know wether it still holds after all this time.
jdugen is offline
post #5 of 8 Old 07-16-2011, 3:55 PM
all forks from 92-99 will fit, rrn,rrp,rrr,rrs,rrt,rrv,rrw,rrx models.
The uk fork recall was for the 929 and 954 fireblades, I don't remember the early carb blades having a recall, i may be wrong.
stevecbr1000 is offline
post #6 of 8 Old 07-16-2011, 8:06 PM
Reputation Power: 12
Yea the forks will fit but the spacing for the caliper mounts differ on the 98-99 for the bigger discs,also the early blades had no compression adjuster on the lower fork.
Just look for any bar the 98-99 forks. It would be far cheaper to buy a used bent set like i did just for the lower sections.
Slapsider is offline
post #7 of 8 Old 07-17-2011, 11:10 AM Thread Starter
Thanks for the help guys firstly gonna give honda a call see bout this recall if no joy there i think im gonna try what slapsider suggested and swap the ends off some bent forks, failing that i will just sell the bike broken minus the price it will cost to fix, slapsider do you know if the ends off any blade forks are compatable with mine?
post #8 of 8 Old 07-17-2011, 11:21 AM
Yea any lower sections will work bar the later ones 98-99 w/x
Front Forks 2008 Blade. Firestarter Honda FireBlade 17 04-22-2011 12:43 AM
Weight of early Blade muffler GammaBlade Honda FireBlade 0 03-08-2011 1:36 AM
Early Blade front sprocket cover QQQ Honda FireBlade 0 03-12-2010 7:59 PM
Wanted - exhaust hanger bracket for early blade ndj Wanted 4 02-16-2008 5:21 PM
Inspired by the early pix of the '04 'Blade... flasher2001 Honda FireBlade 15 10-10-2003 11:09 AM
