Replaced stator, burned sockets?! - Honda Motorcycles - FireBlades.org
post #1 of 2 Old 07-10-2011, 3:50 PM Thread Starter
ok guys here is my issue i replaced the factory stator with a aftermarket one, i had to re-pin the factory socket coming from the stator. My question is, is there any difference between the 3 wires coming off the stator?
Since the aftermarket stator had 3 solid yellow wires i was not sure which ones went where in the socket so after pondering it for a bit i decided they were probably all the same. Well now i just unplugged the socket and the center pin is burnt to hell along with the socket. I'd say its safe to say they are not all the same and at this point i am stumped as to how to resolve this issue.
Any help would be great, Thanks!
Jersey954 is offline
post #2 of 2 Old 07-10-2011, 9:57 PM
Reputation Power: 10
Re: Replaced stator, burned sockets?!
Was the bike not charging? I replaced the stator on my bike cause it wasn't charging. I also burnt the plug. How old is your battery? Did you check the rectifier? What happen to me is I changed the stator and it melted the plug and burnt the wires pretty bad. I checked the battery. It comes out that the battery was bad. I brought it to the local battery store they told me that you can only run them flat a few times and then they are no good. This is the bad part I open up the stator again and checked it one of the poles burnt out. I fried the stator. So what i did was ordered a new stator, rectifier and battery. Changed them all at the same time. And now the charging system seem to be ok. I get 14+V at idle.
samson929 is offline
stator burned up rexx890 Honda CBR 600 4 05-19-2013 12:03 PM
Engine and swingarm castle nut sockets Mattress Honda RC51 3 06-28-2006 2:01 AM
question on pin spanner wrench or steering stem nut sockets... SomeStrangeGuy Tools / Garage / Paddock 6 06-16-2006 12:21 PM
?'s for those who've replaced their stator cover... J.R.rider13 Honda FireBlade 5 03-05-2006 9:21 AM
